+ Reply to Thread
Results 1 to 20 of 37
Thread: vac pump and rig
    Jun 2013
    calgary
    vac pump and rig
    right now i have a two stage 5cfm infinicon pump but lately i noticed it is not pumping down like it used to. i expected this as it was a cheap pump at the time. now im looking to invest in a well built pump and i am looking for suggestions. maybe even some advice for a improving my vacuum rig. right now im just pure residential 5ton and down.
    cheers
    Jun 2001
    Louisville, KY
    What are you using to connect your pump to the system?
    Yakima, WA
    I've had a JB eliminator since I started and it has served well.
    But - before that, when is the last time you invested in an oil change?
    Jun 2013
    calgary
    i have the titan manifold 4 valve set with 5' ball valve hoses and a yj super evac micron gauge. i change my oil after every job and if its a long pump down ill change it half way through.
    Mar 2001
    Ilwaco, Washington
    I've still got my original JB that I bought in 1979. A second JB came my way for $150 in 1982, from a tech's widow. (still have it) Also have a Ritchie that is heavier than my ex wife. Now using an eliminator every day in my van. Still like my JBs the best. Biggest problem I see are not enough oil changes and guys trying to evacuate with rubber hoses.
    One way to outthink people is to make them think you think. They'll think you're not really thinking what you're trying to get them to think you think...........
    Jul 2009
    Kansas
    Tip: Get rid of the manifold and long hoses. Get Vac Rated Hoses and Connect Directly Pump to System.
    Jun 2001
    Louisville, KY
    Quote Originally Posted by chuck0norris10 View Post
    You're likely leaking under vacuum through the manifold and hoses. Get a vacuum hose and connect to pump. Save the manifold for charging.
    Jun 2013
    calgary
    so would you have spliters at the service valves with ball vales to separate the vacuum system from the charging system.
    http://www.appioninc.com/products/vctfeatures.html
    Use two.
    Jun 2001
    Louisville, KY
    Yep. Those are my favorite.
    Jun 2013
    calgary
    ill be picking up those monday morning. what do you guys think of the yellow jacket superevac 8cfm pump as another option?
    Used one for years. Still sitting in the garage, waiting for my cheap, lazy *** to buy a new coupling for it.
    Using a JB eliminator right now. I like the built in fittings on the JB vs the home-built rigup I had to do on the YJ.
    Dead tough pumps both of them.
    Apr 2011
    Coastal Maine
    Agree with the others. Lose the manifold when pulling a vacuum. I am partial to the JB's. They have been bulletproof for us. We have between 15-20 of the 7 and 10 CFM Platinums in service at the moment that get heavily used and all still going strong. I like the metal handle, the built-in fittings and the rugged construction. They can handle the abuse. No plastic on them. I hate plastic crap.
  14. #14
    Jun 2013
    calgary
    i am not partial to plastic either, why did the refrigeration trade have to be so "cool" to get into. all these expensive toys
  15. #15
    Aug 2009
    Maine
    Not much. Go with the JB, or if you want to spend some $$$ a tez8 Appion.
  16. #16
    Jul 2012
    i have two yellow jacket super evac system 1's. i use a supco vg64 micron gauge. Don't ever use a manifold for vacuum. They leak under vacuum and will not pull low enough.
  17. #17
    Jun 2013
    calgary
    in residential will i notice a big difference between a 7 cfm and a 10 cfm ?
  18. #18
    Jul 2012
    not at all
  19. #19
    Madison In.
    ya what is the deal with manifolds. they can be under pressure and not leak. put them in a vacuum all bets r off
    Sent from my SCH-S738C using Tapatalk
  20. #20
    Jul 2012
    Quote Originally Posted by Rhinohead View Post
    not sure but i believe it is the valve packing. The seals actually seal from the pressure pushing from the inside out. Vacuum pulling inward probably unseats the seals.
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
