Results 1 to 12 of 12
    Ottawa, Canada
    Munchkin Boilers
    Any of you guys have the opportunity to work on Munchkin boilers? Had a bit of a nightmare today with a few of them at one of the schools we service. Very "awkward", to put it nicely, to service. School board is considering installing more of them at another site. After today I was considering discouraging more of them. Thought I'd see if it was just me or if anybody else shared my opinion
    Dec 2001
    Southern Tier, NY
    i'm not impressed
    Mid-west
    I like the Lochinvar Knight better, same basic design but better. Easier to service and more efficient.
    Dec 2001
    Southern Tier, NY
    far better choice, the Knight
    Western New York
    Have you seen one jump off the floor when it goes to light yet?
    Jun 2006
    Hastings, MN
    The biggest thing is install them right. So many bad installs on them 10' of 1"gas line up to the valve CO2% 8-9 they run a long time. Yearly maintenance a must.
    Aint Notin Sweeter, Then A Brand New Heater!!!!!!!!!!
    Western New York
    The Munchkin is engineered on price and poorly designed. Too many nuisance failures with text book installations. Kind of like the Land Rover I have...I will do the customer a favor and spend the extra 500.00 and install an Ultra.
    MA
    I've had three service calls for munchkins, all three the plastic impeller on the draft inducer was in about a thousand pieces
    Puget Sound, western wash.
    I have serviced quite a few of these. Only problems were from installers giong outside specs. The install guidelines should be reguarded like a bible. Only service problem not related to install was having to adjust firing rate, which you have to use a combustion analyzer, and set up burner Properly. Ilike them, and they are one of the few condensing boilers approved for potable water use.
    Park City, Utah
    Ever hear of a problem with using the munchkins with a heat exchanging water heater, where the heating loop fails and adds glycol to the domestic water?
    yes I have had exchanger failures, though not specificaly with munchkins. That's also why we use propalene glychol almost exclusivly. (it's the main ingredent in creme soda).
    Grottoes VA
    Quote Originally Posted by dsfitzgerald7 View Post
    At least the new ones are stainless steel
