    North Carolina
    New Tracker panel cable
    Hello all,
    Can anyone tell me the Trane part number for the cable to hook up my laptop to the new Tracker panel ???
    I have the Tracker software but have lost my cable.
    Thanks for any help.
    RC
    controltech01
    If you have a LAN connection on your Tracker Panel, Assuming it is the New Tracker 12 or 24 you can give it a Fake IP address and connect using Ethernet, with out buying a cable. Use a crossover.
    Go to advanced on the touch display and set up the LAN settings, disable the DHCP, and use any valid IP, like 192.168.1.100, then open you soft ware and make a new connection using the ethernet.
    Feb 2005
    Where it's dark & damp
    Cable 3591 4260
    9 pin adapter 3591 4262
    25 pin adapter 3591 4263
    North Carolina
    Thanks to all
    I appreciate your help.
    Have a great evening.
    RC
    controltech01
