+ Reply to Thread
Results 1 to 12 of 12
Thread: compressor blowout help
    Apr 2014
    pittsburgh pa
    I was working on ptac islandaire unit. Came in with not nowing anthing so but on bench to do check on it. Plug it in fired right up let run for couple minutes and such off. try turn in back on i hear the thermal disk over load go off. cycle unit it keep triping go get thermator and shell reading 145F so think it probaly bad ill take it out check operation turn unit back on stays at 145f up to about 155f i see smoke go to shut off push off buttom and reach to unplug . BOOM Hollywas that scarry. not sure why at that temp this happen. i think major restriction or something else mechanily wrong any thoughts.
    Southold, NY
    That is why you never run the unit without the cover on.
    Hope your OK
    The heat was from the windings shorting out inside.
    Jun 2012
    Arkansas
    Yep....she gone.... How old is the unit?
    Jul 2012
    I always recommend using a blow off valve with the waste gate pressure set to 300 psig
    Apr 2014
    pittsburgh pa
    Do realize that talking about Hvac 410 a compressor were would you put waist gate. There not even gauge connection on ptac you haft punch tool pull the gas and put on in youraelf
    Jul 2012
    Lol
    Apr 2014
    pittsburgh pa
    I'm guessing that means no I'm surprised haven't had mor comments on this
    Apr 2012
    Every compressor self cools with the suction line gas. You said bench test ... something tells me the problem wasn't in the compressor.
    Economy - Quality - Speed <---- pick two
    Jul 2014
    I noticed a couple of things, either the charge was low or when you tested the compressor, you had the doors open and sucking in all the how air. Or both.
    Apr 2014
    pittsburgh pa
    I did not have time to do all the test do to blow out on ptac the high pressure switch is normaly so when shut off on bench test that what thought was wrong until kick on again an then off I could here the click of thermal overload. Amp draw was 27 witch was not to high for start up but trip out to soon to get run amps so removed limit and went boom there was something major wrong but not sure if was compressor or not hate replace compressor to find out have stuck vale or restriction some were. Still trying to get all info from island aire to make fusion but they pain to deal with slow
    Don't remove the thermal overload when you don't have gauges connected to see what is happening in the refrigerant circuit.
    West Plains, Missouri, United States
    May be a dumb question. But are you certain you were connected to the correct voltage?
    ie: 240 volt on a 110 volt motor wrecks havoc and smoke.
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
