Results 1 to 7 of 7
    About YORK cooling unit/condensing unit
    This is a York cooling unit. maybe it's a condensing unit. I'm not sure. The model #. is H2CB048S46A. I checked web, and could not find anything about it. Anyone knows what this equipment is? Thank you!
    Looks like a generic 4 ton straight cool outdoor unit.
    Nov 2005
    Shreveport, Louisiana
    Quote Originally Posted by yesky View Post
    Is there a difference between an cooling unit and a condensing unit...
    sorry, not enough info
    SE GA at the moment
    Quote Originally Posted by berg2666 View Post
    The only "cooling unit" I am aware of is a BTU which is a unit of cooling measurement. "Cooling unit" is not a professionally used term by itself.
    A condensing unit is the outside portion of a split A/C system (the type of system in most non-heat pump residential applications). That is what that part number describes, a 4 ton condensing unit.
    Most would call it a condensing unit if it contains the condensing coil and the compressor. I'm with retired (I wish I were retired too) that a cooling unit is not a term for machinery.
    This is a York Equipment. The model #. is H2CB048S46A. I checked web, and could not find anything about it. Anyone knows what this equipment is?I think it's old. Thank you!
    The details on the label are:
    Central cooling Air Conditioner:
    Compressor: 460V/3/60
    Fan motor: 460/1/60
