Results 1 to 12 of 12
    NAE25 Metasyssyagent Password Reset
    At one of our schools we have the NAE25 metasys control. Recently our maintenance tech passed away, he did not use his computer to store the password he either wrote it down somewhere we can't find or just remembered it, and so we are unable to get into the system.
    The default password will not work. Does anyone have an idea on how to reset it?
    Dec 2006
    There is no NAE25, only 35,45, and 55.
    Anyways, there is no simple way to reset passwords
    without blowing the database away. (N.U.T. the NAE)
    Then reloading it.
    Are you sure you typed in the correct default password?
    It is case sensitive.
    user: metasyssysagent
    pass: XMG3-Rel.1
    Why would anyone give a password to one poster that is working on a nae that does not exist.
    Dallas, Texas, USA, Earth, Milky Way
    Phantomtech: That password and log-on information is freely available in the public domain on the JCI literature website if you know where to look!
    dewright23: If the default has indeed been changed, then all you can do is return the controller to JCI factory for a reset. You will loose all database information also. May be quicker to just replace the master controller with a newer model.......
    Jan 2005
    NAE25 Password
    There is an NAE25. It is the NCE 25. It comes up as an NAE25 when viewed in NIC tool as NAEXXXXXXXXXXXX (Default Name and MAC Address). I'm assuming that you are trying to access it through Ethernet. If so, the Default username is-metasyssysagent and the Password is-XMG3-Rel.1. I'm also assuming that this an NAE with points. As previously mentioned, if the default name and password have been removed,and you don't have the database then it would have to be reflashed and the you would get the defaults back.
    Jan 2005
    NAE25 passwword
    As an added note, this is their newest product
    Quote Originally Posted by phantomtech View Post
    Just google: metasys default password
    2nd hit shows the password right in google, dont even have to go to the website, so i dont think its to big of a deal to give it out.
    Mar 2006
    Quote Originally Posted by buzzman View Post
    Its awesome!
    There is a *possible* way around this problem. IF you have access to SCT and can restore teh security database, it will ask you to readd the default password, which has already been mentioned here. The NAE in this case is not removed or go offline. BUT you have to have access to the SCT and have a password to run it. I know.....lots of ifs and buts.
    Dec 2006
    NAE and NCE are different controllers so THERE IS NOT a NAE25.
    Jan 2005
    Nce25
    Easy there JCI Dork! Its called an NCE but at its core and when booted up through the NCT tool Gives its name as NAEXXXXXXXXXXXX. I originally tried to tie into my first NCE by using NCEXXXXXXXXXXX, didn't work. If JCI would make the default name NCEXXXXXXXXXXXX then I would agree with your statement. Obviously the author of the original posting knows he has a 25 of some kind.
    Jan 2005
    Nce25
    Dwright23,do you have I/O on your NCx?
