+ Reply to Thread
Results 1 to 20 of 30
Thread: Goodman ARUF - Scratching my head?
    Jun 2012
    Arkansas
    Ok, never encountered this before. We installed an ARUF Air Handler w/ 10-kw heat strip kit.... Quadruple checked everything, thermostat connections, wiring, etc.......
    When the breaker is turned on, blower motor runs continuously..... pulled thermostat, blower still runs.... Pulled "G" wire from board, blower still runs....... I originally thought maybe stuck sequencer, NOPE! Checked for voltage across sequencer and heat strips, nothing..... I could find nothing that's "calling" for the blower to operate......
    Here's the strange part.... I pull the purple wire from the normally closed side of blower relay, and the blower stops immediately.........
    Maybe a stuck fan relay? ........
    Jan 2014
    Mesa, Arizona
    Possibly fan relay, seen this in a few goodmans and Coleman's
    We all make choices, but in the end our choices make us.
    Aug 2011
    bad board will be my first guess!
    Jul 2009
    South Carolina
    Sounds like it's wired wrong. If you can't find anything wrong with your wiring, don't assume the factory wiring is correct. It could be a bad board or relay but less likely. I'd be looking to see why the purple wire has power on it.
    It can even be the wires crossed in the molex plug.
    Gary
    http://www.oceanhvac.com
    The best things in life are free but not everyone is willing to pay the price.
    When you appreciate what you have, you have a lot more.
    Jul 2012
    Its either wired wrong or the fan board is holding the fan delay on or the relay is stuck. Pull the green and white wires offthe fan board, turn it on and see if the fan runs. Unplug the heat kit and put the little plug back on the harness that has the two red / black wires and give it 230v. See if it runs.
    Jun 2012
    Arkansas
    Ok, will do.... I'm starting to lean towards the fan board, because if I pull the purple wire, everything works perfectly....... It's the only way the fan will stop running.
    Jun 2012
    Arkansas
    Quote Originally Posted by garyed View Post
    I even checked that....LOL!
    Jun 2012
    Arkansas
    Quote Originally Posted by Rubio480 View Post
    Recently? Was it in a new installation?
    Jul 2009
    South Carolina
    If I'm understanding this right this is a new install where you pulled the purple wire off the NC point of the relay that is on the board to stop the fan. That means the purple wire should go to the heat relay and should only have power if the heat relay is engaged. That leaves something in the heat strip kit. If the heat relay is not bad then possibly an element got banged up during installation and is grounded.
    Gary
    Jun 2012
    Arkansas
    Quote Originally Posted by captaincompressor View Post
    Did this also..... works perfectly without heat strips with the standard 2-wire molex plug
    Jun 2012
    Arkansas
    I wondered about that, but there was no voltage going through the heat strips.
    Jul 2012
    Quote Originally Posted by Dr Love View Post
    the heat kit may be wired wrong. it should have a blue common going to each sequencer. there should be a brown or white going to the sequencer low volt input.
    I cant remember on goodmans if the sequencer pulls the fan online or not. look for M1 and M2 on the sequencer and see of it leads to the blower some way.
    Jun 2012
    Arkansas
    Blue on one side, white on the other, for 24 volts....... Sequencer does pull the fan online........ When there's a call for electric heat only, W2 closes at thermostat, but "G" doesn't close, so the purple wire is supposed to provide fan operation whenever the heat strips are engaged. It's supposed to be there as "back-up" so the heat strips never operate without the fan......But......
    Even though I measured no voltage across the sequencer, I replaced it out of curiosity......Blower still ran continuously
  14. #14
    Jul 2009
    South Carolina
    Usually one side of the element is always hot but it wouldn't have to be if it was grounded. The purple wire would act as a neutral if it was grounded and complete 120v. circuit to the fan motor when connected to the board. It would make the fan run slower than normal though. If that were the case then something would blow if the heat strips were engaged so I'd do some more checking to be safe. I would check the purple wire to the other hot leg to see what voltage you're getting. It's even possible that L1 and L2 are mixed up at the heat strips and you're getting 240v. feedback through the strips to your purple wire that's causing your motor to run.
    I'd love to see an actual picture of the heat strip wiring.
    Gary
  15. #15
    Jun 2012
    Arkansas
    Am I allowed to upload pictures?
  16. #16
    Jul 2009
    South Carolina
    I think so but I forgot we're not in the pro section so responses are limited.
    Gary
  17. #17
    Jun 2012
    Arkansas
    Yep, it was the fan relay..... it blew
  18. #18
    Tulsa, OK
    I would immediately see if 20 amps is pulling with the new board at the 60 amp breaker and if so then that will take out the new c/board running both cooling and a sequencer bridged post to purple or (Common Side of the 240 volt eventually burning up wiring etc.) *using purple and red in a dark lit attic is APITA* on ARUF's, see it all the time so you have to stare at it wire by wire three times to catch the FUBAR done at the factory or at the heat pack division. I have found that comparing the online schematic to the sticker in unit can be the culprit so go by the online or call technical and get walked through it wire by wire. "It's just going to be that way from now on with any brand out there due to out sourcing and getting rid of people that have technical intuitive brain cells".
  19. #19
    Jun 2012
    Arkansas
    Quote Originally Posted by JBM1000 View Post
    That's what happened when the purple wire is connected. If I leave it disconnected, it works beautifully,even in emergency heat.
  20. #20
    Jul 2009
    South Carolina
    I apologize if i'm wrong but I'm starting to think this is a DIY job so I'm going to bail out of this thread. This is too simple a problem to need this much attention.
    Gary
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
