I have a TAC UNC at the job site with Tridium framework. I am integrating that with a Delta System. The Delta system is a DOW 322 version with about 12-15 different controllers. Everything from boilers, AHUs, UVs, and an ERV or two. The main Delta controllers (DCU-050 & DCU-050-30a) each has the ethernet expansion boards (DXC-052-3).
I am assuming I will just be extending the controller level network (BACnet) to my UNC, add it as another node. I am just trying to find out ahead of time any problems I may run into.
If anyone has integrate with Delta and can give me some guidance or comments I would appreciate it.
