    Jun 2001
    San Diego, CA
    Honeywell Lonstat - can't find stats
    As the owner replaces units, some are being changed out to HP's. The 7300's require a separate sub-base for conventional or HP. We can no longer get either.
    Hwell no longer sells the 7300 Lon stats that this program was made for. Are there any other stats out there that will be compatible with this outdated program?
    Feb 2005
    I thought kele sold 7300 lon stats at some point, they may still have some stock.
    Maybe check with them.
    Jan 2002
    Fort Worth\Dallas, Texas
    What program are you using, Lonspec?
    Honeywell sells the T7350 which replaced the 7300. It will do multistage conventional ac or heatpump and is a Lon communicating stat.
    http://customer.honeywell.com/techli...0s/63-1299.pdf
    You can use these with Lonspec
    Go Rangers!
