Results 1 to 7 of 7
    MA
    Paloma Instant Water Heater
    Is anyone familiar with Paloma instant water heaters. I found one with a frozen water coil. The OD temp was about 3 degrees. According to the Users Manual the freeze protection on the unit was only good to 4 degrees, Lower than that you are supposed to drain the unit. Thats a little rediculous if you ask me. Sorry its 2 degrees outside today, you can't take a shower. But anyways I wanted to check the electric heater, and the freeze protection t-stat on the unit, but I don't know where they are in the unit. There is a thin sheet of plastic in front of the coil that looks like it might be the electric heater, but im not possitive. Has anyone ran into this problem before? Thanks for any help.
    Nov 2000
    Eastern PA
    I don't know much about water heaters but Paloma, I believe, is the largest water heater company in the world. Paloma also owns Rheem Manufacturing company which makes water heaters as well as Rheem, Ruud and Weatherking HVAC systems.
    Point being, Paloma is an upstanding large company.
    Government is a disease...
    ...masquerading as its own cure…
    Ecclesiastes 10:2 NIV
    Mar 2001
    www.tanklesswaterheaters.com - you should have your mo# & se#
    You get what you paid for. The builder saved money installing that 'type' of HWH.
    Outdoor HW down south
    But I wouldn't mount anything outdoors if it gets that cold.
    MA
    Quote Originally Posted by johnsp View Post
    It's not outside. I guess because the flue is so short you get a pretty strong down draft.
    MA
    M# Ptg42pvn
    S# Pjng0406p000350
