Results 14 to 19 of 19
    Mar 2006
    Hopefully cleancondenser will respond. He is the metasys master. He can help you out.
    Near Philly
    Here is a DX9100 Metastat slider setup I have used in the past, it may not be correct for the the slider you are using.
    Measurement Units = 0
    Type of Active Input = 2
    High Range = 7.4
    Low Range = -5
    High Limit = 100
    Low Limit = -10
    Filter Cont = 0
    Limit Diff = 2
    The Rest = 0
    Mechdorn
    I was looking at the metastat, product info and this looks like it may be right, anyway it will be a good place to start.
    Nov 2007
    I am not sure if this would even work...? But-
    How about using TE-6700 series room sensors with the warm cool adjust?
    Might (can) they work somehow with the DX-9100 AI's?
    Colorado
    You can use the TE-67NT-1N00. The product cut-sheets will guide you through the install. Both inputs will be passive AI's, as the slider is just a straight potentiometer. Set your desired range on the passive AI and your good. Hope this helps.
    Jun 2001
    San Diego, CA
    seems to me the sensors are 1kohm. If the slider is anywhere near this any old passive input would do. Just see what values it gives and plug them into a segment module for your output. If you want setpoint with the slider for for plus/minus add a calc module.
