Results 1 to 10 of 10
    Oct 2005
    Omaha, NE
    Sanyo Minisplit: Switch between interconnecting cable???
    Thanks all for recent recommendation of Sanyo Minisplit.
    I am having my local HVAC Co install the unit.
    It is Sanyo 12KHS71 (AC + heat pump), 12K BTU unit.
    The installer is doing a good job and we were looking at the installation manual that came in the box.
    1. The DISCONNECT Switch for Power Supply between the house's brick wall and the OUTSIDE Unit: This is installed and looks good. This is Electrical Code and understandable. No problem here.
    2. But: the installation manual Fig 23 states that there should be a "Disconnect Switch" (Field Supply) in the Interconnecting cables between INSIDE and OUTSIDE Units. See attached pic.
    My HVAC tech told me usually he does not install this "indoor" "Disconnect Switch" as it is not needed.
    So I am confused.
    Is this "indoor" "Disconnect Switch" needed?
    Thanks again.
    Fujitsu is the brand I prefer and install. They, meaning all of the ductless manufacturers, all show this switch on all of their diagrams and manuals. I have never installed one. I pull permits and have my work inspected, it has never been an issue. I have never seen one installed on someone elses work, either. I look at the switch as being a nuisance, because if I need to work on the indoor unit, I turn it off at the disconnect anyway, and sometimes I need that power on to the indoor unit to troubleshoot. Even though with the Fujitsu line that's been rare. Cost is not an issue, the cost and time to install this switch is minor and would not impact the job, I just feel it is redundant, and another thing that could fail or go wrong. Now, if they said a FUSED disconnect was mandatory, then I'd install one.
    Oct 2005
    Omaha, NE
    Thanks for your reply.
    You are absolutely correct.
    The HVAC tech talked to other techs at his company and the reason for this indoor switch is that if a tech needs to work on the indoor unit, he can turn the indoor switch off and works on the indoor unit WITHOUT pulling the Outdoor disconnect switch.
    Again, as you said, it is redundant because if you decide to work on the indoor unit, you may as well pull the Outdoor switch.
    Thanks for the clarification. We will skip this 'useless' switch.
    burlington county n.j.
    by code the switch should be there. there should be a means of disconnecting power within sight of the eqipment being worked on. what if a tech is working on the unit and someone plugs in the disconnect outside??????.
    The outdoor unit's disconnect is the way to power off the indoor unit.
    Do you notice the oval around the two 115 volt lines?
    This is a 230 V disconnect that will cut the power to the indoor unit.
    Do you really want a disconnect installed on your wall?
    Philadelphia, PA
    Quote Originally Posted by billva View Post
    A 2 pole 20 amp toggle switch works fine. It is a safety issue and required by electricalo code.
    It is required by electrical code.
    It is seldom installed.
    Jun 2001
    Louisville, KY
    This is the correct answer.
    LINE OF SIGHT...doesn't mean a disconnect at the ODU!
    As comfortdoc noted, just install a switch.
    Oct 2005
    Omaha, NE
    Now I am confused! It is election year (ha!) so we need a vote among the "pros": To install the switch or not???
    Jun 2001
    Louisville, KY
    No vote about it. The code and the install manual win every time.
    Have it done right.
    A simple 2-pole switch with proper ratings will work just fine. Don't have to install a disconnect box on the wall. It will look just like a light switch.
