Thread: K and U
    K and U
    Hello friends,
    what is the differece between U Factor and K factor
    Ramana
    New Mexico
    Tracers work both ways.
    WHY
    Las Vegas NV
    Quote Originally Posted by ramana1574 View Post
    Hello friends,
    Ramana
    The answer is alot of formulas etc....a Google search would show these.
    Quick answer:
    K factor: Thermal Conductivity, defined as the rate of heat transfer through a homogeneous material in BTU per hour per square foot of area per F temperature differential per inch of thickness.
    U factor: Thermal Resistance, defined as the resistance of a material to heat flow and is, by definition, the reciprocal of a given heat transfer coefficient.
    Don't I sound smart?
    Actually this information came from the Krack refrigeration manual.
    Jan 2005
    Denver, Colorado
    K factor is straight with three angles. U factor is very curvy.
    Leadership...the ability to move forward even when you've burned your foot.
    Because
    Till now i am calculating cooling loads manually with know concepts and by taking U factor in to consideration.
    Now i have started using a software called 4M Fine HVAC which is an integrated environment with drawing for cooling load calculation, psychrometry calculations and air duct network design.
    This s/w is using SI units and they are considering K factor for all walls, openings etc..
    I am getting the results almost similar if i consisder the same ufactor as kfactor.
    ramana
