Results 1 to 7 of 7
    humidifier sail switch...
    Hello,
    I have a sail switch that activates my humidifier. Problem is last week it got stuck in the off position. My humidity went down to 25% during the night.
    I would like to eliminate the sail switch and get something else. The switch worked fine for a couple days then stuck again. I wiggled the assembly, then it opened the valve and water started flowing again.
    What is better way to do this? Would a relay switch be best or would a pressure switch? The humidifier is a Honeywell one if that matters. It is one that uses a plug in AC to DC converter.
    I have a booster fan on a relay already. I was figuring on jumping off of the leads used to activate the booster to another relay that would open the valve then passed a voltage.
    Types of parts recommended would be appreciated. I am guessing a relay would need voltage or a pressure switch would just hook inline.
    Any suggestions would be appreciated.
    New Mexico
    A pressure switch might be the ez way as it could be mounted in the same place with the same wiring and costs about the same as a sail switch. I never liked sail switches.
    Tracers work both ways.
    Afton, VA / Khorat, Thailand
    Why not use a humidistat or thermidistat? I hate a sail switch too......
    Midnight Sun Astrophotography
    Quote Originally Posted by tunnel_rat View Post
    I have a humidistat and it works in conjunction with the sail switch. If I were to only use the humidistat, then the accessory would be on even if the heater was not. Bad waste of water.
    Quote Originally Posted by leon phelps View Post
    If wired properly, the humidifier won't run without the heat.....
    Jan 2005
    Denver, Colorado
    If you're not going to use a humidistat/thermostat to control it, I would definitely use a current sensing relay. Very reliable, inexpensive and completely enclosed switching. Call a professional, though...this is not a job for a HO.
    Leadership...the ability to move forward even when you've burned your foot.
    I wired the pressure switch in line so that the humidistat will only have electricity when there is air flow.
    The system works like a charm.
    I now do not have to worry about waking up in the middle of the night with a dry mouth.
