Results 1 to 4 of 4
Thread: Furthest room in house too warm. Any upgrades/improvements/changes?
    Dec 2012
    Hi there,
    I live in Arizona and during the summer the 2nd room in the house has a wall that gets direct sun from the south and from the west. The A/C unit is on the other side of the house and I find that this room is always warm. The rest of the house is kept at 79F, but this room feels much warmer.
    I have a ceiling fan in the room that helps, but its still not the best.
    Do I have any options to increase A/C airflow into this room, or any other suggestions that I may have not thought of?
    The A/C was completely replaced in 2012 with a brand new one from prior owner. I have done nothing to the A/C since ownership.
    Thanks!
    Aug 2013
    Visalia California 93291
    Need to know the required CFM for that room- What kind of exposures (exterior walls) does that room have as well as windows
    If the unit is low on air would not be surprised to see "to small of duct" issues- If you are needing air would like to know unit size as well as return duct and main supply duct size
    south louisiana
    could also be heat gain through the walls/windows.
    any exterior shading on the exposed walls?
    Jun 2005
    SW Wisconsin
    Do a heat-gain on that room so you know the required Btu.hr, from that U can determine the CF?M required; I'd divide the Btu/hr by 26 to get the CFM high enough.
    Let's say it requires 4,500-Btu/hr / 26 (26 is around 450-CFM per ton) is 173-CFM; divided by 2 is 87-CFM each of the 2 diffusers with a direct in room Return air for that amount of CFM with extra large Return Air filter areas to conform with ACCA Manual D requirements.
    Do that room with this load-calc
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
