Results 1 to 11 of 11
    Is Air leakage acceptable?
    I noticed on my new furnace installation that there is a lot of air leakage where they connected the new ductwork to the the outlet on the furnace/coil. It seems like there should have been some sort of sealant. This seems inefficient or I am being too critical. I noticed the leakage when I was standing by the furnace I felt the draft in my face. There are open holes on all of the corners and alot of air leakage on some of the sides as well.
    Nov 2001
    Seattle, WA
    Pictures?
    - Alexis de Toqueville, 1835
    Mar 2006
    no its not acceptable, unless you want to heat/cool your attic
    My furnace is in the basement and I am talking about the ductwork connected to the outlet on top of the furnace as the hot air leaves the furnace and is entering the ductwork. The is air leakage all over.
    Nov 2001
    Seattle, WA
    Air should not leak out of any of the duct work at any point. It's that simple.
    Mar 2006
    Quote Originally Posted by Bruce3301 View Post
    depending on if the plenum isnt cut to the right size as the supply end of the furnace, it may need to be redone. The Plenum should be Mechanical attached to the furnace as well as Sealed with a good mastic tape around the joints. I'm sure that if you have air leaks at this point, you probably have many other leaks.
    may want to have someone come check it out for you becuase you are literally throwing money out the window
    Minneapolis, MN
    How much leakage would you accept from your plumbing system? Just because air doesn't leave a mess doesn't mean it should leak out of every connection. Some day properly sealed ductwork will be standard.
    Massachusetts
    If plumbers installed the plumbing in your home the way the HVAC installers installed the furnace, would you accept the plumbing leaking all over the place? Just because it's leaking air, doesn't make it okay. They should have sealed it.
    TN
    Hey Bruce call your installer and you should get a reply something similar to this If not get tough with them. Expected reply "Those darn apprentices, sometimes they forget to seal the joints. I will have them come back and put some Iron grip 601 mastic on the leaks Mr Customer Sir we are very sorry for the inconvenience." Of course it should not leak LOL
    oregon
    Sounds like a sloppy install. Belive it or not I have heard talk at the parts house counter that is is ok not to seal duct that is in the basement, it helps to heat it!!!! Have the salesman come back and show it to him. A built in hair dryer on your furnace/duct is not effcient!
    Genius = The guy who can do anything...except make a living!
    Mar 2006
    Quote Originally Posted by geodude View Post
    heat the basement, in that case just wire some 120v space heaters to a switch that closes when you open the door to the basement.. or those nifty propane heaters
