Page 3 of 3 FirstFirst 123
Results 27 to 32 of 32
  1. #27
    My Advice is that you should not take anyones advice on brand from this forum. the majority of the people inhere that are qualified also sell thebrand they support. do research locally as the installer is as important as brand. I sell Trane so i say go with Trane.
  2. #28
    Nov 2000
    Eastern PA
    Quote Originally Posted by warmncomfy View Post
    Good advice right to the end. Well, just short of the end
    Another thing to consider in brand is how well the brand your contractor wants to install is supported locally. If a brand of equipment is not locally supported to the contractor, the contractor is automatically at a disadvantage to support that brand in a consumers home.
    Government is a disease...
    Ecclesiastes 10:2 NIV
  3. #29
    Jun 2007
    The Twilight Zone
    Plus, when used with a variable speed blower that GSH14 is rated at 15 SEER.
    The optional TXV must be installed to get 15 SEER (12.5 EER) from the GSH14 heat pump.
  4. #30
    Nov 2000
    Eastern PA
    Quote Originally Posted by gary_g View Post
    Should use a txv no matter what.
  5. #31
    Florida
    I thought you were a orifice guy??? He got ya.......
  6. #32
    Nov 2000
    Eastern PA
    Quote Originally Posted by smokin68 View Post
    Got me with a double entendre too, depending on which orifice you are referring to
    For condensing units and heat pumps, I am fine with fixed metering as long application factors are conducive. If a system is going to be operated in cooling mode at lower then 70 degree outdoor temps on over 13 SEER systems, I prefer to see txv metering.
    For this particular set up there are only a few ratings that don't require a txv and most of them are for horizontal slab coils. I guess that rating with fixed orifice might give some edge on systems that are super tightly bid. Other then that, I see no reason to rate without the txv.
