Results 1 to 13 of 34
    Heat Pump Keeps Running
    Good Evening To All:
    I have a Heil heat pump, (sorry no model number at hand) and I have what I believe is an unusual problem, as this is my first home with a heat pump. On the heating cycle the blower motor will keep running between cycles and even if I turn off the heat it will still keep running. While this is an occasional problem, when it does happen the only way to turn off the blower motor is by throwing the circuit breaker.
    The unit is about 7 years old and I have had the thermostat replaced as well as the computer board in the air handling unit. The aggravating part about this is it does not happen all of the time, nor has it happened when the service tech has been in our home. Does anyone have any ideas or heard of this type of problem? This is my first post here and I thank all in advance for any information anyone may be able to provide.
    DC Metro Area (MD)
    Have you had the thermostat replaced?
    "I have had the thermostat replaced "
    Well,that what he posted???
    DC Metro Area (MD)
    Calm down there. We all make mistakes. I missed that.
    Unfortunately, nothing has changed. This is a foreclosure home purchased in 2003 and shortly after moving in that summer we had to have the blower motor replaced. At that time I did not think much of the problem but now with
    the blower motor running like it does I tend to believe that was the reason the first motor was replaced.
    In addition nothing changed with the replacement of the computer board. I thank you for your interest in my problem.
    Florida
    Why was the board changed? It sounds like it could only be a couple of things....you might want to try another another service company....
    Jun 2001
    Louisville, KY
    Why do you continue to attempt to answer questions pertaining to HVAC? Just curious.
    I don't know
    Myrtle Beach, SC
    I have seen it in many brands. Caused by a flaky heat sequencer.
    Remember, Air Conditioning begins with AIR.
    DC Metro Area (MD)
    Quote Originally Posted by jrbenny View Post
    Emailed.
    N.C.
    Could be the fan relay going bad.Also check any delay timers.To check sequencer...... if you don't know then call a qualified competent tech and have him check your wiring and your control components
    I'm not a professional
    So don't pretend to be one... No one comes here to get half-baked answers from fellow non-professionals.
    Lancaster,Ohio
    Talking
    I had a problem close to that a few years back...It was a thermostat wire that was shorting out in a staple to the bottom of a floor joice. When someone steped on it, it cause the fan to start to run. I pulled a new wire and the problem was solved!
    IcyFlame
