Results 1 to 7 of 7
Thread: Data logger
    philadelphia, PA
    Hmm Data logger
    Anyone using data loggers such as "Onset Hobo" to do energy audits, especially on hydronic systems? I would like to monitor oil/gas boilers to look at short cycling, efficiency, zone, etc problems.
    Apr 2002
    I use them, more for IAQ, humidity and cooling issues
    http://www.ductstrap.com/
    Massachusetts
    We have some but have used them minimaly. We found that generally a good troubleshooter or the homeowners themselves can tell what the problems are closely enough to remedy any errant situations. The loggers can be very helpful if a client is accusing an installation of being deficient in some realm. No one can tinker with them so they really do deliver the true news. In that regard they're quite helpful.
    philadelphia, PA
    Question data logger
    Preference for software or hardware configurations?
    Apr 2002
    Hoboware Pro software.
    Can monitor temp, rh, CO2,outdoor temp/rh, when equipment runs/stops
    philadelphia, PA
    Cool data logger
    I looked at "Hobo" by Onset and wasn't impressed with their software . So in doing a web search I came across this site which may be a little better and cheeper. http://www.omega.com/ppt/pptsc.asp?ref=OM-50 I'm going to try their products and I'll let you know. What I would really like is a data logger to use with Honeywell L7224U aquastat which would constantly log the boiler cycles, but I haven't been able to locate one yet.
    Apr 2002
    to each their own I guess, the software launches the loggers you tell it how frequently you want it to take samples, retrives the data, plots it
    you can monitor events with it when stuff runs, when it is off.
    Good luck in your search
