Results 1 to 10 of 10
    Oct 2006
    Confused heat will not shut off
    hello everyone,
    quick question, my furnace will not shut off. Does anyone have any idea what this problem could be. maybe give me a couple of ideas on how to diagnose this problem. any info. will help tremendously. thank you all very much.
    SE Michigan
    Sounds like something went wonky, service call time.
    “Now the freaks are on television, the freaks are in the movies. And it’s no longer the sideshow, it’s the whole show. The colorful circus and the clowns and the elephants, for all intents and purposes, are gone, and we’re dealing only with the freaks.” - Jonathan Winters
    leland nc
    turn it off at the emergency switch and call for service
    there is no way of knowing what is going on over the net
    in my lumpy chair
    turn it off now and call for service or you can wait and call the fire dept. latter
    I dont warranty Tinkeritus
    Oct 2007
    Southern Ontario
    t-stat? Set to 'off' not 'heat' and see if the furnace shuts off in a couple minutes. If it continues running turn off the switch at the furnace and call for service. If it shuts off, call for service and a t-stat
    Illinois
    Based on this and...
    previous posts you are a diy'r. Call a pro and have them check out your entire system and be done with it.
    Call a tech, save yourself some grief.
    Jun 2007
    Tillsonburg ON
    Turn off switch at the furnace, and call a service tech.
    houston
    I think mine phone is ringing
    that's a good call
    Jan 2006
    Word! Call a tech.
    rick
