Results 1 to 13 of 32
    Question proper location of filter
    Is there any advantage or disadvantage to having the return air filter at the end of the return plenum rather than at the beginning of the return plenum? In particular, I'm asking whether one location is more efficient than the other in terms of filtration and maximizing air flow.
    Chicagoland
    I'm not a pro, but I would think the closer the filter is to the unit, the better results you will get, since there is less distance for the air to travel after it has been filtered. (since the returns could be dusty or have air leaks, etc)
    somewhere between heaven and hell
    I always prefer at the furnace for a filter to me it seems more efficient like in a return drop boot that comes off the furnace they return air drop boot is popular in MN cause most furnaces are in the basement here. Plus if you put it at other end you gonna make sure it is picking up all the return in the duct from the house other wise it does no good if you know what I mean. That is my opinion.
    Oct 2007
    Southern Ontario
    Filters go in the return air plenum at the furnace. Why filter the air than have it travel another 10' once again picking up dust and who knows what else!
    What does your furnace installation manual say?
    If your looking to maximize air flow, look at what you are using to filter rather than where its done
    Hmm
    Quote Originally Posted by mobileguy View Post
    If the ducts are sealed, how does it pick up dust in the ducts? Looks like both options are equally good. Hopefully a pro will chime in at some point and confirm that.
    DC Metro Area (MD)
    Quote Originally Posted by charles2 View Post
    You'd be surprised at what some ductwork looks like on the inside. Dust is sucked into the ductwork at the returns from the home itself. Filters don't necessary stop all dust. Please correct me if I'm wrong.
    Return ducy leaks can be an issue.
    That aside the size of the filter is limited at the plenum/eqipment,when they are at they grilles,they can b larger and more efficient,since the air will move slower the larger filters.Also less restriction to air flow.
    Hmm
    So basically you agree that either choice is fine?
    I prefer filters at the grilles ,for the lower restrictin to air flow ,if designed larger.
    Nov 2000
    Eastern PA
    Less static pressure to contend with when the filter is located right at the blower housing.
    Also, a filter grill of the same size as a filter in a rack at the furnace will have about 40% more restriction due to the actual free area of the grill.
    If you are going to have a grill located remotely from the air handling unit (furnace) it should be significantly larger to accomodate added ducting static pressure as well as free area restrictions of grill. Also, the ducting between the filter and the blower compartment "MUST" be 100% sealed, and that includes all connections and even screw holes.
    ...seek, and ye shall find;..
    Ecclesiastes 10:2 NIV
    Quote Originally Posted by RoBoTeq View Post
    RESPONSE:At the furnace is typically smaller ,lso more restriction,no brainer!
    RESPONSE:You'll still have a grille ,so it's the same restriction ,no brainer.A non-filter grille ,plus a filter at the furnace is the same restriction,other than style/model differences,as a filter grille.
    RESPONSE:Yes the sealing of the return duct is more important with filter grilles.
    The total restriction/static of the return system will be no different with a filter of the same size at the grille or at the furnace,no need to be larger if at the filter,although it can be which is a way to reduce the static,whereas you have limited filter size at the furnace!
    NO Brainer Again!
    Is this my Christmas Present???
    Florida
    Easier to change out in a filter grill and keeps the ductwork cleaner, so my preference.
    Quote Originally Posted by smokin68 View Post
    No comments on robo's opinion??
