    OPtional Tracker software
    Was reading about Tracker and it mentioned 'optional Tracket software'. Will Rover do Tracker? Is there a seperate Tracker program?
    NY
    Tracker is separate software. It used to be included with a Tracker but now you have to buy it. It is fairly inexpensive/
    Hoboken, New Jersey
    Also
    If you get a Tracker with display you can generally do most of the controls through the touchpad. I found it relatively easy to configure the CCP's on the network. However the VAV's can be configured through Rover or The Tracker Software. When I tried to use the touchpad to set stuff like my temperature range for the thermostat thumbwheels I encountered some issues. You are best to get the Tracker software so you can backup all your settings and stuff as well in case something goes wrong.
