Results 1 to 13 of 18
Thread: Taylor soft serve
12-21-2007, 10:09 AM #1
- Oct 2007
- Oregon
- 73
Taylor soft serve
Hi I am working on a 30 year old two head machine this unit should be in the graveyard. It has 409A in hopper compressor, 408A on one side and 134A on the other side. The complaint was ice cream not coming out fast enough and product spoiling in hopper. I think the ice cream problem can be solved my using metal scrapers instead of plastic and correct me if I am wrong. The ice cream temp is 19 degress. The hopper refrigerator is working good but I do get temp difference from the front to back 37 degrees in front and over 50 in back can this be a bearing problem on the auger? Next question is can this problem be solved? Thanks Paul
12-22-2007, 01:39 AM #2
- Jan 2007
- 166
I just fix one last week.
Problem is the gear box worned -out.
And I have to replace the bearing kit and lubrication.
Have you replace the bearing kit every half year?
12-22-2007, 10:00 AM #3
- Oct 2007
- Oregon
- 73
Okay can you tell me what all is involved in doing this?
12-23-2007, 03:31 AM #4
- Jan 2007
- 166
Try their website,they have good information there.
12-24-2007, 03:06 PM #5
- Oct 2007
- Oregon
- 73
01-01-2008, 01:24 AM #6
- Nov 2007
- State College, Pa.
- 42
Let me guess, the hopper used to be R-12, and is a cap tube system. If my guess is right, try recovering the R-409 and replacing the cap tube and filter. When R-409 was first introduced, it was advertised as a drop in replacement for R-12, later they found that the cap tube wouldn't work, and recommended it be replaced with a longer one. Take the compressor hp and cross reference it on a Supco cap tube chart, as the factory isn't going to have any recommendations.
