Results 1 to 13 of 16
    propane fired furnace smoking black
    I recently purchased a used furnace from my hvac contractor. He converted the burner from gas to propane. The furnace ran fine, but was smoking black out the stack. He came back, took out the baffles on the burners, and said now it is fine. The thing is still not burning clean,it uses an excesive amout of fuel. The contractor tells me that the furnace is working properly. Can anyone advise me?
    Feb 2007
    Las Vegas,NV
    nobody can advise you here, because we are not allowed to offer do it yourself help. Working with propane is dangerous! If the dude that set it up for you is not solving the problem, then call in someone else to look at it for you.
    burlington county n.j.
    Thumbs down
    black smoke from propane is a BAD, BAD thing. shut it down and get it looked at by someone else...........
    Arkansas NWA
    The furnace isnt the only thing blowing smoke,,,sounds like the contractor is to!! Previous posts are absolutely correct,,,,propane is very dangerous. Get someone who knows what they are doing!
    Minneapolis, MN
    Turn off the furnace. Turn off the gas. Call a qualified service company to repair. The last guy failed and left you in a dangerous situation. We would hate to hear about you on the news.
    Suppy NC
    used furnace and black smoke non of this is good. You are in a very dangerous situation
    turn it off and call a qualified server company to check this furnace
    Hi, Thanks for the imfo, I fixed the problem, wrong orfaces, good advice to shut it down
    it was starting to get hot.
    Toledo, Ohio
    He bought Twilli's book
    No Heat No Cool You need Action Fast
    Montgomery, NY
    Wrong orfices
    It obvious the the guy that installed it and converted it dont know is orfice from a hole in the ground. I would strongly recomend that you have your Propane company go over the installation. On the brighter side its like a suicide bomber it will only go kaboom once.
    WE LIVE IN THE LAND OF THE FREE,
    ONLY BECAUSE OF THE BRAVE
    Toledo, Ohio
    Twilli wonders what the LP pressure is? Buy Twilli's book and you'll know
    N.E. Ok.
    Quote Originally Posted by paint4metal View Post
    It's obvious you didn't take the good advice offered.
    Your contractor is dangerous and you are putting yourself and others at risk.
    Shut that thing down and call a qualified tech.
    It's hard for me to believe this contractor holds a valid lic. What does he do for X-mas hand out live grenades.
    N.E. Ok.
    Quote Originally Posted by twilli3967 View Post
    Captube was wondering what manometer the DIYers were recommending.
    MN
    Quote Originally Posted by captube View Post
    manometer? can't you just listen for the right tone from the burners?
    You can't fix stupid
