Results 14 to 25 of 25
    Oct 2007
    Milwaukee,WI
    Thats gotta be fun to demo.
    ___________________________
    Chicago is an indian word for stinky!!!!!!
    -supertek65
    Enfield, CT
    Smile Hey Mike Holmes would be mad.
    Mike Holmes likes to use the Blue Spray foam in just about all of his rework projects. If they used that stuff with the right sprayer(sprayee) it would look decent. Just a thought. That yellow crap looks terrible the way it was applied. Looks like the Units could double as Rock Climbing wall.
    MN
    Quote Originally Posted by fridgitator View Post
    If it's the same as Great stuff, it won't hold up long outside unless it's covered. It's UV sensitive, and breaks down quickly in sunlight.
    yes if it is outside it needs to be painted over. We painted with roofing sealer(white stuff like trailer roof coating.)
    You can't fix stupid
    Quote Originally Posted by ar_hvac_man View Post
    Paint it brown and it would look like a turd.
    LMAOOOOOOOOOOOOOOOOOOO!
    South Amboy, NJ
    thats friggin crazy.....and it looks like **** to boot
    somewhere between heaven and hell
    now thats funny. NOT
    Oct 2006
    In a freezer or in an attic somewhere
    Speaking of turds. You can only polish a turd so far, the end result is, it is still a turd.
    Great work. WAPOS!
    Massachusetts
    What's used is a 2-part foam. But if it doesn't have the proper flame propigation characteristics, it can only use for sealing leaks. We did do 1/2 a system once using the 2-part foam on a very specific install. The problem was that the old furnace was in a crawl where the ocean visits every year or three. So we replaced the furnace to the 2nd floor attic but we still had to duct down from the attic to the crawl space distribution. We put in all new ducts as the old ones were rusted out from the salt water. So what to do? New ducts will be junk in a couple of years if we use standard wrap insulation and the insulation will be junk too. So why not spray foam? Give the right amount of R-factor (1.6/inch). seals agains air leaks and when the ocean visits, it hopefully will prevent infiltration of salt water to the ducts. And should the ducts rust out, I guess the foam form is the new duct system!! Not pretty but it was the only solution we had for this unique situation. Comments?
    Oct 2006
    Ron Pepal said it best,"Set it and forget it"!
    Dec 2001
    Ocean Pines, MD
    Had a hotel do that in the sub ceiling. Had to take steak knives from the kitchen to find the modulating valves.
    Huntington Beach, CA
    can you imagine having to remove that when it doesnt pass inspection...
    Hell Hole Swamp
    Stuff works great in attics, not on ductwork but on the underside of the roof, attic temps stay a few degrees above room temp, you could work up in the attic all day even in the summer
