Results 1 to 13 of 21
    Dec 2003
    Middle of Florida
    Solder job gone bad.
    Guy before me had a little trouble with this one, 10 lbs of solder later he called me in for a look-see.....cut the hole thing out and started over.
    http://good-times.webshots.com/photo...02715250OIDkdP
    http://good-times.webshots.com/photo...02715250KLHTOd
    If common sense is so common how come so few of us have it!
    Ohio
    Wow....didn't we have to watch a movie about that kind of thing in high school sex education class?? Looks like a bad case of the herps
    solder probably weighed more than the valve your holding
    Dec 2006
    Middle Tennessee
    looks like he used the -15%
    SC
    Maybe he charged by the pound...
    Dec 2003
    Middle of Florida
    Valve had water leaking by it, just enough so that he could never get a pinhole sealed, to much water vapor.
    I used one of those cordless Rigid crimping tools and crimped a male adapter on a valve up stream and just ate the water that was running out until I could screw on a new ball valve onto the crimped male adapter.
    Boise, ID
    You're last post just invalidated my observation. Guess I was not fast enough on the draw.
    Sep 2006
    wow i feel good about myself now....there is somebody worst than me out there
    SC
    secorp,
    Next time screw the valve on the crimp adaptor BEFORE crimping. Leave it open until after the crimp. Will save you a few gallons cleanup.
    Dec 2003
    Middle of Florida
    That's a great idea to be sure.
    I only had 1.5 inches if that to work with after the last valve, I was not sure it would even crimp, but I heard the snap. the last valve actually was holding a little so it was not to bad of a stream, still that is A damn good idea.
    Jan 2002
    Ft.Worth,Tx
    Quote Originally Posted by secorp View Post
    This looks like he tried to use silflos 15% with turbo torch.. Seen that type before myself, DYI trying to fix it himself.
    'Life begins with the journey each day'
    Chester County PA
    So what does everyone think of those crimp connectors?
    I've used them a couple of times since my employer just got the new toy but I'm concerned about the o-rings going bad in the future.
    -smoke-
    "That motor's done, he let the factory smoke charge out!"
    Dec 2003
    Middle of Florida
    I do not get to do much water pipe, but the guys who have used them swear buy them, they are expensive.
