Page 3 of 4 FirstFirst 1234 LastLast
Results 27 to 39 of 41
  1. #27
    Vacaville Ca not the prison
    Common?
    Recently found a dowflow/ horizontal in undercrawl had what customer called (special vent pipe) high temp plastic sealed with rtv customer said just needs a service a 15 year old rheem with 5 holes in the # 3 tube flame roll on fan start finally got bad enough to open roll switch looked like it had hammer holes in it. Isthis common on rheem /ruuds?
  2. #28
    Oct 2006
    houston
    all furnaces since 91 had spark ign or HSI, I have been a RUUD dealer the whole time either it is alot more the 10yrs old or the temp is a crack head-self proclaimed engineer jacka$$ and decided to redesign the furnace while high on previously mentioned crack
  3. #29
    Oct 2006
    houston
    has anyone else seen in Rheem and Lennox furnace a rust likeline develope in the heatexchanger as the burners inshot but it doesnt open, cvause flame disturbance or emit co into the airstream?
  4. #30
    Shreveport, LA
    Whats with the standing pilot system?
    Someone downgrade it from HSI?
    Carrier had one
  5. #31
    Jun 2006
    Quote Originally Posted by ruud-man View Post
    Sammyray...
    I think if I came across a 2 year old heat excahnger in that condition I would be checking a few things. Temp rise too low, return air too cold, or VOCs in the air.
    I wouldn't be surprised if the second htx lasts abot as long as the first...
    Best regards,
    The reason that furnace look that bad and heat exchanger was rusted out. The roof had a water leak and the customer never change the air filter. I should have took a picture of the evaporator coil it was a classic.
  6. #32
    Quote Originally Posted by lil' randy View Post
    Looks like it must have been a RGDG/UGDG which was eventually replaced with the RGPH/UGPH model. That Inducer motor here in Ga runs about $ 150.00+ to the trade to replace and the vent tube and shield is another C note. I sell an average of 30+ of the replacement inducers a season.
    The RGPH/UGPH model was HSI, which eventually got replaced by a DSI control.
    Martin
    whaaaaa, you let all the smoke out
  7. #33
    Dangerous is an understatement the pilot flame also gives off c.o gas which is the reason for the hood w/tube lucky someone wasn,t killed by the looks of that unit, that kind of stuff makes real techs look bad
  8. #34
    Jun 2006
    Quote Originally Posted by Jims understudy View Post
    I agree with you...
    That customer was lucky that the pilot kept going out.
  9. #35
    I agree with agentphelps...why a sane person would not instantly cap that line and red tag is beyond me. that thing just looks horrendous.
  10. #36
    Nov 2007
    WOW Carbon Dioxide Hmm
  11. #37
    Florida
    I can't imagine a service tech doing something like that. More likely a handy man or even the homeowner.
  12. #38
    that tech should be beating within an inch of his life
  13. #39
    Jan 2005
    Jenison Mi
    well isn't that special.
    Everybody has the right to be stupid. Some people abuse the privilege.
