Results 1 to 13 of 14
    chicago
    residential air flow
    Can anyone tell me how many cu in. I can get out of a 6" duct. The reason I'm asking is, I have a lack of airflow on the opposite end of my house. I have a 4 ton drive serving a two story at approx. 2800 sq. ft. thanks
    Huntsville,AL
    no
    not enuf info
    how long?
    how many fittings? where are they?
    what type of fittings?
    joints & cracks sealed?
    what size trunk?
    what size plennum?
    how many other ducts?
    what size, etc?
    what size blower?
    etc, etc.
    Sep 2001
    Vancouver Canada
    110 cfm if duct is sized right.
    "Go big or Go Home"
    6" duct ,could be from 40 to 120 cfms,depends on the rest of the duct system.
    If space is available the duct system can be remediated,to correct any issues.Follow Man. D.
    in my lumpy chair
    calla pro to calculate and identify your problem
    I dont warranty Tinkeritus
    SW FL
    next AHU changeout .. go to a Variable Speed ( if not already done so)
    Designer Dan
    Not a tough question, just too many variables..kind of like asking how much water can i get out of my 1/2" garden hose?
    Class of 70
    houston, texas
    2800sq ft with 4 tons of air , doesn't compute in Texas. Not enough information.
    MA
    Quote Originally Posted by Black Adder View Post
    depending on the static pressure
    Boise Idaho
    Quote Originally Posted by Bruck View Post
    my house in boise, 2755 sq ft, 2-story with a 4-ton. Variable speed with 2 -stage (5-ton drive set at 350 cfm). Winter temp 0 and summer high 108. Strugles about three weeks a year upstairs and runs all day. Have a new 432 true zone on the work bench, just need the time to do it.
    matt
    Dec 2006
    Arkansas
    You're correct, but only because you can't determine what size unit is needed for a given house size unless you have all of the information about the house. That goes for Texas or Alaska. I know of houses in Texas with 500-600 sf per ton and houses with 1000-1200 sf per ton. There are too many variables, but in most cases if the number turns out to be 500 sf/ton, it is probably too large. A load calculation is not sf/500. It involves a little more work.
    Jun 2001
    Louisville, KY
    Just did a home that was 1300 sf per ton. I did the load 4 times before submitting to customer.
    Home had a 12-foot wrap around porch. No window load.
    SW FL
    Cool
    Quote Originally Posted by tuckerin View Post
    3.46 GPM
    on an average day
    Designer Dan
