    10 lbs stuff (5 lbs bag)?
    Has there ever been more stuff crammed in one spot than a newer under counter Traulsen? (the type that a broiler fits on)
    Southern,Ca
    are you talking about the drawer system, that the condensing unit slides out of
    Jul 2001
    Gold Coast of Connecticut
    They are the absolute worse piece.
    Aire Serv of SW Connecticut- Gas heat, dual fuel and central a/c systems installed and serviced
    Slides sounds so easy Yes that's the one.
    Southern,Ca
    The concept is great if you didn't have to get to the back of the box to take out the four screws. but once those come out it's not too bad. We had alot of problems with the intellitraul module's shorting out from them hosing the floors off! We finally got rid of the controller and installed a temp control and time clock and it worked just fine!
    Ever change a compressor? Bring a box of bandaids
