check the velocity at the diffuser neck, it shall not more than 4m/s ,
I've got an office suite with Titus MCDAA, square cieling diffussers. The occupants are complaining of drafts even after I changed the 4-way pattern to push air away from them. I'm looking for a diffuser that will spread the flow horizontaly accross the cieling.
If the diffuser is designed for the ceiling and has the airflow in its designed range, it is NOT blowing on the occupants. I've seen smoke tests in a lab for diffuses, and the air goes across the ceiling and down the wall with room air being pulled into the center of the diffuser.
So if I understand what has been said, I should not be able to feel any air movement if I'm near a diffuser, if it's right for the application. The reason I want to clarify this is that there is no commercial building I've ever done work in where I haven't had complaints of "feeling the air."
I had someone complain yesterday that they were feeling a draft. For some stupid reason, the mechanical company ( who wasn't too bright to begin with) decided to use an open, natural draft retun system in that specific area. Well I stood by her desk and kind of felt the cold draft, but I'm also moving constantly while she's sitting in her clostrophobic cube all day. I just ended up shutting the FPM on 2 diffusers in half by her and added filter media ontop of the return grilles, seems to work ok, haven't had a complaint yet. So you might want to try that even in your diffuser, just remember to change the filter media cause it gets dirty over a couple months time pretty quickly.
Well in my instance it was the draft from a return, and I was hesitant to close the dampers slightly due to unbalancing the system, but that's all I was left with unless I made the returns a force draft, which I'm still considering. But this was in an open office area, it won't work for all enviroments. I would just change the filters out on the weekends..lol
