Results 1 to 13 of 18
Thread: AC built into duct????
12-11-2007, 02:28 AM #1
I recentinly helpled my dad change out his 1950's furnace with a new 90% gas setup. The Question I have is for the residential pro'S IS CAN I SIZE AC DUCTS TO CARRY WHATC HE NEEDS IN BOTH AC/HEAT APPLICATION'C????
12-11-2007, 02:37 AM #2
Depends on your duct work, a/c requires more air volume that heat.
You could always do a Manual D. Duct work being from the 50's most
likely duct work is to small for a/c.
12-11-2007, 07:16 AM #3
Read site rules. No DIY issues can be dealt with.
Everyone has a purpose in life..........even if it's to be a bad example.
Seek first to understand, before seeking to be understood.
12-11-2007, 10:22 AM #4
- Jan 2004
- 48
The question should read "may I size ducts for both heat and AC?" Yes but can you?
Class of 70
12-11-2007, 02:17 PM #5
- Jun 2005
- 274
01-13-2008, 01:40 AM #6
Hay Irish I'm a 10 year Refrigeration guy dont do much residetial Thanks for the help
01-13-2008, 06:47 AM #7
Yes you can.
The ducts must be sized to the higher air flow requirment weather its for heating heating or cooling.
In my area, its almost always the A/C that needs the most air flow. But once in awhile its the heat.
But we can't discuss any more detail then thatg in the open resi forum.
Apply for pro membership.
01-13-2008, 07:28 AM #8
- Dec 2007
- 132
Of course you can put in an A/C coil ,I can't figure out why everyone on this site is so hesitant to help. All you have to focus on is the return duct if the supply has been there from the 50's Great it has worked for a long time onlt issue with supply is make sure it is sealed and maybe insulate it,other than that you might have velocity a little high ,but hey you cant have everything right.The key is you can never have to much return air ,It wouldnt hurt to add some ,the system was probably sized for heat only back then,So put in your coil ,seal &wrap add some return & new t-stat and enjoy!!!
01-13-2008, 07:43 AM #9
Because you guys don't read the rules! READ THE RULES! NO DIY! There is a forum for this, it's the Professional Technical Forum.
There is a link to the forum rules as well as a link to apply for pro membership in my signature line.
We do not want specific step by step instructions in the open forum where Joe Homeowner can see what's going on, try it himself, fail and blow his butt to Kingdom Come!
01-13-2008, 07:54 AM #10
- Dec 2007
- 132
Relax Bob the man is a pro asking for advise he is doing ref not gas piping ,Why would he blow his own fathers house up?
01-13-2008, 08:18 AM #11
- Dec 2007
- 89
effiency!thats what u need to focus on, I would advise u to get a contractor over ASAP!
01-13-2008, 08:36 AM #12
01-13-2008, 10:46 AM #13
