Results 14 to 18 of 18
01-11-2008, 06:51 PM #14
New Guest
- Dec 2007
- 3
Good question. Once I figure out the size I need, I'm going to pull the trigger and buy a furnace. I think I definitely want a two-stage, but I'd love some guidance about brands. I keep seeing Goodman advertised...claiming to have the best warranty, etc.
How do you folks feel about Goodman? What about other brands?
01-11-2008, 07:05 PM #15
Professional Member*
- Nov 2004
- SW FL
- 5,263
Trane / American Standard / ( I-R )
Carrier / Bryant
AAON
Lennox / Armstrong
York
McQuay
Rheem / Ruud
Mitsubishi
Climatemaster
Thermastor
.. much of equipment selection is based on Particular need/product, Familiarity, Warranty and Support
.. take your pick
http://www.johnmills.net/work/history.html
Equipment is 40% of the project. ... Installation is 60%
Bid three or four mechanical contractors and
throw out the lowest bid.Designer Dan
It's Not Rocket Science, But It is SCIENCE with "Some Art".
01-11-2008, 07:56 PM #16
- Nov 2007
- Livermore, Ca
- 163
01-11-2008, 08:21 PM #17
- Nov 2007
- Livermore, Ca
- 163
oops. I tried to copy and paste a chart from a consumer reports repair history. I typed in, consumer reports furnaces, and hit search.
But me no howz. Anyway, it had American Standard as least, then Rheem, Trane, Ruud, Bryant, carrier, Heil, York, Amana, Lennox, Tempstar, and Goodman in that order. The margin was slim but nonetheless.
01-11-2008, 11:46 PM #18
Reiterate previous responses. Yes a new furnace will be much more efficient...but you MUST do all of your insulating/windows/structure improvements first. As previously stated, a proper heat gain/loss can't be done until we/they can determine infiltration rates/ R values/etc. If you buy a new 90+% variable speed dual fuel system @ 100kbtu and have it installed in a what will be in the future an overinsulated energy star home, you will probably still be oversized... causing assorted other problems..ie short cycling, shortened equipment life, high humidity etc. A variable speed system along with the structural efficiency changes you propose would go a long way toward solving your stratification problem... but read previous posts first.. If you are not done with the insulation and windows, you are not ready for a new furnace. Oh yeah.. It's perfectly reasonable to join for only one question... I think that's why we are ALL here.. doesn't mean it will be your last. And you have asked nothing but reasonable questions ...IMO.
"Surprised ?! If I woke up tomorrow with my head sewn to the carpet, I wouldn't be more surprised."
Clark Griswold
