Results 1 to 11 of 11
    Oct 2007
    California
    Troubleshoot....on furnace....
    Sorry I forgot the rule
    BENTON, KY 42025
    An open limit switch does not mean a bad limit switch. It means there is another problem causing it to open. Call a proffessional to have your furnace checked, it could be a number of things causing your problem.
    omaha
    check the filter
    Oct 2007
    California
    Thx...
    S.W. PA
    did you read the rules?
    we are not allowed to tell you
    Apr 2005
    N. E. Missouri
    The no DIY in the statement at the top of this page means no Do It Yourself, we cannot help you to do it yourself. There are very good reasons why. You need to find someone (a professional) to find what is wrong and fix it for you.
    Do not argue with an idiot. He will drag you down to his level and beat you with experience.
    Oct 2007
    California
    Sorry....
    Thumbs up i have the same problem
    Quote Originally Posted by charlot View Post
    i am hvac for 5 years.i have a call today some like you.Ls open.the end i found the thermostat bad.but i want found out you problem need the ladder wiring diagam inside the heater.
    Oct 2007
    California
    Can we talk in this forum? Because No DIy?
    I'm new in HVAC, but in Control almost 10. I'm not sure that my problem is solved.
    I did go pt by pt. at the control board and also Tstat...(I'm guessing it may have corrode b/w the sensors and connector. I clean and put them back) Retest...the Temp set pt 3 degree higher than house T... the furnace now is running normal...cross the finger.
    Howell, Michigan
    This forum is not for highly technical discussions, that's why we have the private professional forums.
    If you are a professional in the HVAC industry, click on the link in my signature line and apply for pro membership.
    As technical as I'll get.
    A thermostat won't cause a furnace to trip its high limit.
    jerrick, charlot, make more post, then apply for pro membership.
