Results 1 to 13 of 15
    rackrookie is offline Regular Member - bad email address Contact the Admin
    breaker tripping but not grounded semihermetic Copelamatic
    Two days ago I noticed that one of the compressors from this rack was not running. I checked the breaker and found it tripped. After resetting it, the compressor tripped it again when tried to start. Went thru the already learnt procedure of checking winding continuity and terminal to ground check. Nothing unusual. Tried to start the unit for third time, with the same breaker tripping result. Removed the oil pump and was able to turn the crankshaft by hand, so I eliminated the possibility of a mechanical lock-up. My supervisor suggested an oil check. It came out black and smelly: burnout ??? Removed the stator cover and found the winding mostly ok but with just some blackened coils. How is it possible for a stator to be burnout and still give continuity readings between the terminals and no terminal to ground path?
    By the way, any suggestion for speeding up the process of removing the old gaskets adhered to the semihermetic metal? The knife scrapping method seems to slow to me?
    Balto, MD.
    Did you check the compressor on the ohm scale, and not the continuity scale? It maybe grounded on a mega ohm scale.
    The windings are just not hitting anything going to ground. A motor can trip breakers if the windings have over heated and the resistance between the windings become too low. Usually from a section of them melting, or burning together.
    Orange County CA
    Quote Originally Posted by rackrookie View Post
    Yeah what he said and the gasket thing..use a ball pean hammer(spelling)
    Lightly tap directly on the gasket and it will break loose.
    Another market guy told me this...it works great.
    Medford Oregon
    using Copeland's electrical handbook, get the resistance value of the winding in ohms. if yours does't jive with the book, compressor is toast. turn to turn shorts are not shorts to ground, but will trip breaker. value should be within 5%. most bad windings are not shorts to ground but rather turn to turn shorts. you don't have to guess, just compare Ohm readings to specs.
    Jul 2000
    Guayaquil, EC
    Quote Originally Posted by rocket View Post
    Once again, rocket speaks the truth.
    Check to the spec.
    birmingham, al
    for the gasket, i use brass wire brush on drill.
    Oct 2007
    Did you megg out the windings yet? That will for sure verify the integrity of the windings and their condition.
    Jan 2006
    DFW Metroplex
    Quote Originally Posted by scott210 View Post
    Same here
    Knock off the big chunks and hit 'er with the wire wheel.
    Jun 2007
    SoCal
    Quote Originally Posted by NedFlanders View Post
    smack that gasket hard !!! its already bad !!!
    Mar 2006
    south jersey
    I use the small scotchbrite pads that go on the end of a drill just cover the cylinders with a rag first. Also the same thing rocket said check the Copeland electrical handbook for winding ohm values A good book to have on the truck also.
    Orange County CA
    Quote Originally Posted by AngryReferGuy View Post
    You are too slow..got you again
    an old trick
    Dont use oil to apply your new gaskets. Most of us learned to soak our gaskets in oil before applying them. Years after learning this I learned sometimes its the use of oil when installing new gaskets that makes them stick.
    I always used a single edge razor blade or a sharp gasket removal tool
    maine
    i use a monster scraper.. Like what they use to scrape stickers off windshields.. works great..
