    Recovery time of a house
    Recovery time = time it takes to reach the comfort temperature from setback temperature.
    From that if I calculate time it takes to change a degree at home (rate of change of temperature) is it possible to model this for a particular home?
    On what factor does this rate depends except from insulation of the house? Is it dependent on outdoor temperature and relative humidity in the home?
    Mar 2002
    Concord, CA
    Adaptive thermostats model this internally through observation. Through trial and error they learn how long it takes the home to recover and then adjust how long in advance to come on accordingly.
    For you to do it by any means other than observation? Wow. That's some complex math. Outdoor temperature and humidity have their roles. But I would imagine that the number one factor that we can't measure easily is mass. Heating the air takes no time at all. It's the substance of the home and its contents that takes a long time to heat. How on Earth you'd calculate that, I don't know.
    That complexity is probably why Manual J calculates equipment size based on maintaining a certain temperature in the home rather than recovering from one. Once the mass of the home is at a certain temperature then maintaining that temperature has everything to do with insulation values and outdoor temps and less to do with the mass of the home. As far as I know, there's no conventional software that calculates recovery time. If your equipment is sized properly, your setback is low and if the home chills down then it can take a seemingly long time to recover even if everything is working right.
    Anywho, I'm not much of a scientist. Just giving my 2 cents.
    Oct 2005
    I'm in Minnesota and if I set back 10* this time of the year (about 0* out last night) it takes about 4 hours to recover. This is about a 6000 sq ft house. It will recover quicker on a sunny morning since I have a lot of east facing glass and get some solar gain. FWIW if I totally shut the furnace off overnight the house temp only drops 10-11*.
