Results 1 to 7 of 7
Thread: Trane pcm
    ohio
    Trane pcm
    I've worked with upcmedit a little and I just took on a new building with the older pcms. What does it take to upload these, do I use upcmedit and what type of cable do I need. I see the 25 pin connector inside. Any help would be appreciated.
    Jul 2001
    maryland
    You need pcmedit to upload and the same cable you used for the upcm along with the 25-pin adapter.
    -JB
    ohio
    If this software is different from upcm does anyone have a copy? And maybe a part no. for cable end.
    Oct 2007
    Republic mo
    Send me your e mail and I will try to send it to you. I think you use a 9 pin to a 25 pin connector. The upcm uses a 9 pin to a 6 pin (phone jack style-forgot the name) connector.
    Dec 2006
    Quote Originally Posted by rick4670 View Post
    Can you email that to me too:
    Try: oshimi16@hotmail.com
    Thank you in advance.
    ohio
    ohio
    Did you forget about me Rick?
