    New Orleans, La.
    NAE IP Address ????????
    Is there a procedure for dumping the IP address set in an NAE. Customer computer is fried and they do not know the IP of the NAE.
    Seattle
    Yes, You connect to the NAE with a null modem cable restart the NAE it will give you the currect IP. I have never done this, but I have seen it done.
    It may be easer to just guess. DHCP or Static?
    This tool will tell you who is out there talking.
    http://www.networkactiv.com/PIAFCTM.html
    Mar 2006
    Quote Originally Posted by CascadeControl View Post
    55 Port B , 57600
    35/45 Port A, 115200
    Jan 2005
    NAE IP Address
    You need to make sure you have an ethernet cable plugged in at the same tim during the reboot or you'll get all Zeros. If you have access to IP Tracker(a johnson utility) you could use that with an ethernet cable alone. Let me Know.
Quality Home Comfort Awards
