Results 1 to 4 of 4
    Jul 2002
    NorthEast
    Project builder will not save
    Project BuildeI uploads an N-31 rt
    I hit save as to save the data base
    Edit and re arrange the n-31 points
    Before I close it I hit save .
    I go to open up the data base and all the changes are gone?
    Thank You
    Jul 2002
    NorthEast
    I have a UNT controller
    I am attempting to re order the devices in the UNT's object list
    I want to place more important objects setpoints,temperatures etc.
    towards the top of the list
    I select an object
    hit CUT
    and PASTE it into the UNT
    I re order the list the way we want it
    I save the project , Download it
    But When we open it in ProComm the list is in the original order.
    Do I have to insert a new UNT
    and copy and paste the points in the order I want it .
    into the new UNT ?
    I gather there is no drag and drop feature for each object?
    Thank You
    New Hampshire
    Project Builder organizes objects alphabetically. If you want objects in a specific order to view through hyperterminal, then make a group and you can organize objects any way you want.
    Jul 2002
    NorthEast
    After I add a group or a container,
    Project Builder does not allow me to add controller
    input/ output points (AO,AI,BO etc.) to a group or container.
    It appears that I will have to remove all the points using the VT-100
    and then add them back in the order we want.
    Is there a way to cut and paste them using ProComm Plus?
    Thank You
Comfortech365 Virtual Event
