+ Reply to Thread
Results 1 to 11 of 11
Thread: Condensate Drain Adapter
    Mar 2013
    East Concord, NY
    - Sent via ESP
    Nest is POO!!
    Jun 2009
    South Carolina
    Looks good. You can use the same thing to help bump a drain up to get proper slope for drainage.
    SE Pennsylvania
    Clear view condensate stabilizer.
    Dec 2008
    Buffalo NY
    They lost their 5 cent deposit. Lol
    The future isn't what it use to be.
    Join http://scopeny.org/ Shooter’s Committee on Political Education
    The world is full of sheep,try not to join the flock.
    Support the Skilled Trades, Don't DIY
    Mar 2013
    East Concord, NY
    Quote Originally Posted by qwerty hvac View Post
    Lol. They should have kept it. I took this picture before I went outside. It was a Trane 1200XL installed 7-1988. I dont think it was cleaned since 1988 either. After flushing it clean and running for 10 mins it acted like it was low (very low pressures on high and low). It takes 8 lbs 8 oz so I added R-22 until it reached 63 psi low, 175 high. It wouldnt go any higher. No matter how much I added... the pressures would rise slightly above 64/175 and then drop back. Im 99.999999% sure the problems were at the aluminum coil to copper junctions inside the condenser. They are all horribly corroded and powdery.
    Just to see what would happen I opened the valve fully as liquid into the vapor line. The darn thing didnt even burp, and the gauges hardly moved beyond what I had listed above. I ended up using about 10 lbs of refrigerant, but oh well, such is life. I'm getting the new install and gave a discount on the "test" refrigerant.
    Oh, the compressor had a giant orange bucket on top of it. Made it look like the Great Pumpkin.
    Nest is POO!!
    Quote Originally Posted by HVAC_Marc View Post
    Was the bucket there to hold the condenser fan in place?
    Carpe Carp~ Seize the carp
    Jul 2013
    Richmond, VA
    The Sunkist model is junk. Sell him a Dr. Pepper.
    Mar 2013
    East Concord, NY
    Quote Originally Posted by fridgitator View Post
    Lol no. It looked like it was designed to cover the compressor, similar to the noise reduction diapers all the other manufacturers use.
    Nest is POO!!
    Altmar, New York, United States
    Quote Originally Posted by CircusEnvy View Post
    they just don't make them like they used to.
    Tallahassee, FL
    You sir have a restriction but it's not at the joints that's just impossible. It probably in that pencil dryer or indoor coil or lineset
    Mar 2013
    East Concord, NY
    a restriction would cause a pressure rise someplace. also, the unit shouldnt be able to hold nearly double capacity and not slug and not sound loaded. and the line set at the piston sounds like it's low on charge - not a constant hiss...the random "hiss-nothing-hiss-nothing".
    the charge is going someplace.
    Nest is POO!!
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
