Results 1 to 13 of 36
Thread: Dye Leak Test
    DC Metro Area (MD)
    Dye Leak Test
    Since I've been told I have a big leak somewhere (the contractor said the system was empty; the R-22 had leaked out apparently), the contractor is coming back to perform a dye leak test. I'd like to know any comments on the die leak test. I had a soap bubble test done and that came up with nothing except a leak at a shraeder valve. Is this going to be any better? I'm thinking there's a chance it's in the lineset. I think I've always had a leak for quite some time; perhaps it has continued getting bigger. I told him about an "electronic sniffer" test you guys had mentioned, and he didn't make much of a comment. We are using the emergency heat and will continue to until the dye is ordered and this is scheduled, but I will probably be pushed back since I have some kind of heat (understandable). Thanks in advance.
    A waste of your money!
    BENTON, KY 42025
    I've had some success with the dye, but the problem is it had to be dark when I went back and hit it with the light, and you can only check what you can shine the light at. I like the electronic leak detectors much better. They have improved them a ton in the last 10 years or so.
    If the leak is that big you definately don't need or want dye...tell your contractor to spend some money on troubleshooting tools!
    DC Metro Area (MD)
    What would you suggest if the leak can't be found? Since it is big and can't be found easily, maybe it's in the outdoor coil or lineset.
    how can a "big" leak be hard to find?
    I wouldn't EVER put dye into a system. If he can't find it with an electronic ( or doesn't use one) I would find another company. I don't know who you are using but inability always blames the equipment, or in this case the method of leak detection. Too many bad stories about dyes in systems.
    Hell Hole Swamp
    Quote Originally Posted by air2spare View Post
    agreed
    a qualified tech with the proper tools can probably do so in a few minutes, I would send anyone wanting to use the dye method packing, just my $0.02
    New York
    Ray,
    I have been in this trade for 40 years. The only people I know who use dye for leak testing are auto mechanics and I don't know why they do that.
    When I was an apprentice all those years ago we were taught to use a mixture of dry nitrogen and refrigerant. We used a helige torch and bubbles to find the leaks. Today we use electronic leak detectors but I still think the old way is better.
    We were taught never stop at the first leak but check the whole system.
    If I were to respond to your place for a service call and found your system low of charge or out of charge I would ask you the history of your system.
    If you told me the system has been a problem from day one verses this is the first time it's ever happened it might make my original approach to my leak test vary from looking for the obvious to a more detailed test. but either way I would never stop at the first leak.
    By the way the repair of the leak test is just the beginning of your expense and this is were we always get criticized for the time we spend making the system right.
    Nov 2007
    Durham,N.C.
    Ryan,best thing to do is call a different company or talk to their manager and insist on electronic leak detector if they value you as a customer they will perform the proper leak detection and its probably your indoor(evap coil)or/and condenser coil
    DC Metro Area (MD)
    Well, that's good to know (sarcasm). I'm waiting for who knows how long with emergency heat knowing the dye test is a waste of time/money. Any more comments are appreciated. I think we've had a leak for a long time, as I do recall in the past several instances of us needing refrigerant. The Payne heat pump is SO LOUD that I'm not surprised it can't be heard easily if it is outside. I like the company I use and have a service agreement with them. Should I ask to speak with the service manager?
    Smile
    Ultrasound, followed by eloctronic sniffer and pinpointed with bubbles.
    Isolate condenser, lineset, and coil.
    Technic! Pick a different service company, you are using UAT?
    DC Metro Area (MD)
    Yes I am. Second Opinion, since you live in my area, do you think you could send me an email so I can discuss contractor-related things (my email is in my profile). A little more background info: a company whom I no longer use with good reason installed the cheapest Lennox air handler (I didn't have an option on which one they were going to install by the way, which I regret; I wish I knew more back then. The company is owned by a friend of mine, too.) possible, the CB26UH-R (3.5 tons). Could this mismatch have caused a pressure problem which resulted in a leak? I wouldn't be surprised. I'm sure you guys can understand that I'm a bit weary with going with another contractor. I switched from one contractor to another to find better service (the current contractor is used by neighbors) and here I am currently. I also bought a service contract with them.
