+ Reply to Thread
Results 1 to 8 of 8
Thread: Trane BCI-C RTAC Chiller Setup
    Dec 2011
    I'm trying to set up a RTAC chiller with a BCI-C bacnet controller. I've setup the baud rate and address on the controller. Following the integration instructions, using Techview I tried to enable the CH530 to use the bacnet BCI interface for the BAS communication option but I don't see the "Options" tab listed in the configuration view. I have the latest version of Techview and the MP version is 40 in the CH530. Does anyone have any suggestions or better setup guide?
    Mar 2011
    Long Beach, CA
    Hope this helps
    Jul 2015
    Quote Originally Posted by alcomech View Post
    Hope this helps
    Hi sir. We have trane system with dyana view . Ch530
    .And we have the following problem appear on the dayna view :
    Comm loss: high pressure cutout
    When we use TechView program we find the device is not binding.
    The high pressure cutout swich is Danfoss dual high pressure KP7BS
    Please help me . And instruct us how to bind the high pressure cutout switch. And clear that error.Looking for your fast rep
    NEW JERSEY
    Go into View, Configuration, MP Config. Down to Bacnet BCI-C interface. Change to installed. Then hit load configuration.
    After the Dynaview reboots. Go to View, Binding view. The BCI-clC should have a red, frowny face. Click on it. Hit the bind button. Go to the BCI-C and push the service button. On the the laptop it should ask if device is selected hit yes.
    Jul 2015
    Quote Originally Posted by Zeke XI View Post
    Thanks for your reply. Have you photo for the card you talk about BCI-C . I am not sure if I have this one or not.
    The photo. Or its data sheet will be a great help
    Looking for your reply
    NEW JERSEY
    I replied to the original post.
    In your case go into binding view, click on the LLID that is not bound. Click bind. Go to the panel mount LLID for high pressure, believe it is 1U22. If you put a (south pole) magnet near the white arrow on the board a LED should light. If it does click yes on the laptop where it says is the device selected. If the LED does not light make sure the communication/power wire (ribbon cable). Is secure.
    Jul 2015
    Thanks lot . I think that is really helpful. I will try that tomorrow and tell you the results.
    So grateful.
    Jul 2015
    i have quad relay output card. dual relay card
    when i try one of them the two relay card by turn the led of it on and do bind S letter appear beside the green face\and the compressors doesn't turn on at all ???
    can you help with that ??
    looking for your fast reply
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
