    Buzzing sound from Humidifier
    I recently tunred on my humidifer, it is connected to my furnace. For two days it was fine, now I am hearing a constant buzzing sound when it is on. When I turn it off, the sound goes away.
    I believe it is an aprilaire, not real sure. It is 4 years old and still seems to work fine.
    Any ideas what the probelm might be?
    Jim
    I don't know
    Is this a flow-through unit?
    What you're hearing is most likely the valve solenoid coil vibrating (At 60hz alternating current); if it's intolerable, call someone out to check the connections and replace the valve if necessary.
    Solenoid
    Yes it is a flow through unit and now that I look at the schematic the buzz is coming from the soleniod. It won't cause any problems until I get it replaced will it? Do I have to get it replaced?
    Jim
    Oct 2007
    Mount Gilead, Ohio
    Ive had several flow thrus this year w/buzzing solenoids. 90% of them was no water flow to the solenoid. Plugged saddle valves.
    Valve
    Is this something that I can fix or do I need a professional?
    Jim
