Results 1 to 8 of 8
    Oct 2007
    Orange County, CA
    Unhappy FX40 Retrofit of NAE w/SWCVT Wireless N2 - HELP!
    We just replaced a failed NAE that had one of those SWCVT wireless N2 communications devices on it and are having problems getting the N2 back to communicate with the new FX40.
    Any ideas?
    Quote Originally Posted by esusa56 View Post
    Any ideas?
    As far as I know this will not work on the FX40
    The swcvt is a N2 bus extension over Ethernet IP and talks only to the
    IP Address in the NAE over the customers wireless network. I don't know if the is available in the FX40
    Mar 2006
    There has to be a way.
    What if you had one on both sides. convert RS485 to IP and then back to RS485? N2 devices wired to first SWCVT wireless to Second SWCVT from there wired to FX com trunk.
    Just speculating here. The JCI crap may not be capable, but I am sure something out there is.
    Go here http://www.bb-elec.com/
    Feb 2005
    Edmonton, AB Canada
    Quote Originally Posted by freddy-b View Post
    Good day Freddy,
    You can certainly do this, however you will need a device that is a lot more sophisticated than simple RS485 to Ethernet converters. Sadly these simple convertors cannot deal with all the nuances of Ethernet communication (packet loss, retries, etc) that are necessary for reliable N2 communication. Further, given the Ethernet loading characteristics one also has to deal with variable Ethernet packet times which can vary from below a milliseconds to as high as several hundred milliseconds. It is these nuances and variances that cause unreliable (large number of offlines, etc) rs485 to ethernet N2 networks.
    There are only two products that I am aware of that can deal with this. One is from JCI and is the Secvt which only creates an N2 tunnel with an NAE 5500 series, or our product the S2N2E http://www.s2innovations.com/content.php?id=14). The S2N2E is universal in that it goes from N2 to ethernet to N2 and will work with any type of NC (NCM, NAE, N30, etc). The S2N2E is really quite sophisticated and can compensate for all of the Ethernet issues (these variable packet delays/latencies, retries, etc). The devices are not cheap, but have been used successfully in literally hundreds of locations over the last 4 years (since Sept 2003). In fact, I have two customers that are successfully using them in wireless (5-10 miles using sophisticated wireless technologies) applications.
    Cheers,
    Sam
    Feb 2005
    Edmonton, AB Canada
    Any ideas?
    Good day,
    See my response to Freddy post in your thread. As I stated, you could use our S2N2Es with a suitable wireless technology to extend N2 communications wirelessly. My current customers that have done this stated that simple wireless transceivers (those from BB, MaxStream) just were not reliable enough for their applications. Both of them used sophisticated equipment for their IP/Wireless bridge and have been extremely pleased with the results. Let me know if you wish the wireless manufacturers they used and I will find it out for you.
    Cheers,
    Sam
    Mar 2006
    Sounds too expensive and pretty much pointless then. It needs to be cost effective or whats the point.
    Just add another FX at the remote site and call it good. Probably work better anyway.
    Freddy
    Feb 2005
    Edmonton, AB Canada
    Freddy
    Good day Freddy,
    Indeed, it can be costly... however if wireless is the only option what can you do. The one customer of mine has multiple buildings separated anywhere from 1 to 10 miles and so overhead cabling or working with the telco (it is a remote location) was not an option. Using the S2N2Es was the least expensive option by a long shot. What he did to help offset the wireless costs, was to share the wireless network (bandwidth) with other local vendors.
    Cheers,
    Sam
    Mar 2006
    I understand what you are saying, Then you just go traditional/standard wireless with without the n2 mumbo jumbo.
    Freddy
