Results 14 to 23 of 23
Thread: nest thermostat
    Apr 2012
    Charlotte Area NC
    Why not use an isolator relay?
    Sent from my van
    Jul 2013
    Northern Virginia
    id check the amp draw on that circuit. also when you say nest gave him a new stat did the give him a new module and sub-base? did he/you install both new?
    Feb 2013
    wisconsin
    We wont touch them.... just tell customer we will replace it with anything we stock n work on
    Feb 2002
    Yuma, Arizona
    Quote Originally Posted by tegtma08 View Post
    I will agree with you BUT..... The world will be wanting the NEST T-stats, so you better get used to them.
    My two Pasos.
    Yuma,
    What is snow? Is it that white stuff in a freezer?
    Feb 2013
    wisconsin
    Honeywell wifi lennox icomfort little different but close enough
    Mar 2013
    Springville, NY
    Quote Originally Posted by surenuff View Post
    I am not familiar with this type of t-stat. But for all practical purposes, it should have the same kind of contacts as other t-stats, and therefore should not be dropping voltage though its contacts. Since it does this in the heat mode but not the cool mode, I would think it could have something to do with how the t-stat is sending or switching power to the reversing valve "o" and "b" terminals of the t-stat when it is operating in the heat mode. what kind of unit is it on? This may help us help you.
    nest is all electronic, there are no conventional relays. nest is poo.
    Experience - knowing when to get the hell out of the way and plug your ears.
    san antonio, tx
    Thanks for all the input, i do believe the stat is the problem. taking stat out of the equation solves the problem. the nest tech support does admit power stealing problems with this stat.
    Mar 2013
    Springville, NY
    I got a call today from a Gene La-somethingother at Google Nest Labs. He left a voice message about how he didnt appreciate my calling the Nest "poo".
    There's also a bunch more he left regarding how they're working on staging and other gobbledgygook. He wanted me to call him so we could talk about the issues, etc. (like it's not all been covered here ad infinitum). Though, I'm sure it's more of a sales pitch... trying to convince me to support something I know to cause problems with most everything. It wont even work with the neighbor's 1952 Lennox furnace that runs a 48 volt transformer...
    Anyone else get this call? I still have the number if you want it to give the guy some 'feedback' ...
    Dump the NEST and be done with it.
    No common and it becomes a power robbing stat and as we should know that usually leads to issues on systems other than bare basic types. Even HW puts a resistor in their power robbing stats for certain systems.
    The NEST is beautifully marketed, but poorly engineered. There are far more reliable stats that will give the same results as the NEST.
    Mar 2013
    Springville, NY
    yeah... "Nest is poo"
Quality Home Comfort Awards
