Results 1 to 13 of 21
Thread: Inducer leak?
    Oct 2006
    Inducer leak?
    Howdy.
    I am an owner/builder, not HVAC professional, but I would appreciate help before I spend $$ to have it fixed (or maybe not).
    About a week ago we had a furnace finally fired up. Keep in mind that the guy that did it, has his license only for about 1 year now. Bad thing is that I had little/no choice in choosing him. I can't catch this guy to fix it and retailer requires him to inspect the problem (or finish the install - return drywall cutouts, ect). We find out more and more of bad things he did during this install but it's not the time to bash anyone, just to find a solution to my problem.
    It's a brand new Ducane furnace, upright, with side return.
    You can see where the water leaks. I believe that long black box underneath exhaust fan is inducer assembly. When furnace runs, it doesn't leak. On the shutdown, when inducer motor stops to spin, water shows up in the bottom right corner.
    We checked the furnace if it's plumb and level and corrected it a bit, which kinda slowed the leak process. But it still leaks.
    1. What would be the most likely problem? Bad seal? Would high-temp silicone fix it?
    2. Is that yellow cap on the right side of exhaust clamp supposed to be removed?
    3. Drain pipe from furnace goes to a tee (which gets drain pipe from coil) and runs to the drain. Drain exit from the coil blows warm air when furnace runs. I did remove the coil part but it didn't make a difference in water leak. To properly run both in 1 drain, do I need just an extra vent T before coil drain pipe gets to the main T?
    4. Manual said to prime the drain box. I did but it didn't make a difference for a leak.
    Thanks for help!
    Illinois
    Wow!
    Call the installer and tell him to finish that mess...and fix the unit under warranty...
    Oct 2006
    I called him every single day since last Saturday, left him a message every time. Never heard back from him. Obviously, he's not coming back
    It's winter and I can't have the whole house heated using just fireplaces. My last resort is calling another HVAC guy but that's the extra expense I want to avoid.
    BTW, diode blinks in regular hearbeat mode.
    Jul 2001
    Who is the retailer that requires the installer to fix the problems?
    Nov 2007
    Austin Texas
    Good Advice
    First of all... It is a very bad idea to try and fix this yourself. Safety being the first consideration. Air conditioners are one thing to tinker with, but furnaces are and can be very dangerious. They can and will kill you if you do the wrong thing. One problem can lead to another which the outcome can cause serious injury or death - at the least total property distruction. Here is my advise - Dont try and save a dollar at the possible cost as mentioned above. To say you dont want to incure the extra expense is in my opinion less than in consideration of the possible horrible outcome. Hire a professional to look at the total job - There is most likely more wrong than you even know this moment considering the obvious. Just think if you were the buyer of the home? I am more then sure you dont want to be like the a/c tech who wont return their (the buyers) calls to you, after more problems are discovered? Please do the right thing and learn this lesson... Dont try to save a dime when it will (in most cases cost you much more.
    MN
    can you hear water swishing in the inducer motor when running, if so drain may be plugged, but being water shows on other side of the header, I would say it is a problem with the header assy. call the supply house that the ducanes come from and ask for a service advisor, tell them your installer is not resolving your issues, can they recomend a better company, may have to pay some labor to repair, but parts would be covered. Take the labor off the final payment due, or at least threaten your guy with it, should get a phone call then. You didn't make payment in full yet I would assume looking at the half finished job you got there.
    You can't fix stupid
    Whoever it was in your company that chose the LOW bidder should have to deal with it. When are people going to learn that if a bid is so low that a contractor doesn't make any money on the job then He's going to do a poor job?
    Oct 2006
    Quote Originally Posted by air2spare View Post
    It was me who made this choice. I really regret it but at that time I couldn't have done differently (long story).
    This furnace is Ducane Fits-All 92 and was purchased at Harvey Industries. I have to find the warranty information, but I believe that it covers parts only.
    When You look at parts list, water leaks at the bottom right corner of #67 (cold end box), which covers #62 (condensing coil). If everything was OK, water should exit through #81 (hose kit - inducer and cold box to trap).
    I really hear You when You say about not touching stuff You don't know. I just kinda hoped it can be something simple like plugged hose or faulty seal. I built this house pretty much by myself (and 2 temporary helpers) and I try to approach and resolve problems if I can, before I hire someone else to do it
    What will happen if I call another tech (I know about 2 good ones, referred by my friends)? I am looking for scenario that will cost me least. Simply because I have ~$400K loan frozen in this project
    May 2005
    Western Kansas
    Hire someone to fix that mess up right. Then try to recoup the expenses via small claims court from the original installer. That return alone, shows his skills and doesn't deserve to even be called back in IMO.
    Oct 2006
    I got to one of the good guys but the earliest he can do it is Saturday, which means that we won't have heat for at least couple days (have to tile and grout the mechanical room and floor has to be perfectly dry there).
    Am I asking for trouble by removing the inducer fan and checking how the seal is on that cold end (condenser) cover?
    Nov 2001
    Moose Jaw, Saskatchewan, Canada Occupation:Interprovincial Plumber, Commercial Gasfitter Interests:
    Don't touch it. Grab a electric heater and plug it in.
    And the venting from the fan is wrong. The reducing fitting should be on the vertical pipe.
    I love my job, but paydays Thursday
    Boise Idaho
    that fitting on the side of the furnace is a water trap!! shoud have stayed with the 2" then went to 3" in the vertical. Also your drain tubes apear to be still set for horizontal which is the factory setting. they need to be changed for the upflow.
    matt
    Oct 2006
    Quote Originally Posted by rich pickering View Post
    ... another place that my installer showed his mad skillz
