Results 1 to 13 of 15
    Oct 2007
    Confused Brazing without nitrogen again
    The company I work for has been informed by an employee of a contractor that we are using to install a/c units that they are NOT using nitrogen while brazing. The owner assured us that they ARE Is there any tell-tale signs or test we can do to find out for sure?
    a restriction...
    ...may be a clue
    Nov 2007
    TXV system, check the TXV screen, you will have black residue in it.
    Jun 2002
    Dacula, GA
    Watch them when they are installing the line set at the condenser and see if they are using a nitrogen tank to purge the line. The only other way would be to perform a forensic autopsy of the line set where the joints are brazed. Cut the line either side of the joint and cut across the joint at a 45 degrees and then inspect and if you have a clean joint or back copper oxide scaling or you can give them a polygraph test.
    Sen. Barry Goldwater
    Beautiful, Philadelphia, the City of Brotherly Love!
    Take them to a secret location, beat them to within an inch of their lives then ask them if they are using nitrogen.
    Or, you could look into their service truck for a bottle of nitrogen (orange cylinder) with a regulator on top, if you don't see one they are telling you a fibb.
    Oct 2005
    phoenix az
    Quote Originally Posted by glennac8 View Post
    yep give them a surprise inspection
    "Do not let what you can't do interfere with what you can do"
    "Do what you can do the best that it can be done and no one will ever know what you can't do"
    Southold, NY
    Quote Originally Posted by AtticAce View Post
    Don’t get caught driving around with the regulator on the bottle.
    Sep 2001
    kalamazoo,mich
    My nitrogen bottle is blue.
    Have you hugged the Earth today?
    Donny Baker rules
    N.E. Ok.
    My bottle is black.
    Quote Originally Posted by chucko615 View Post
    Well leave it alone so it can turn back to orange.
    Mine has a label that reads nitrogen, so look for the label.
    In Philly the cops are too busy with all the shootings to worry about regulators on bottles, not to mention they could care less if my truck was loaded with asbestos and waste oil.
    Were alot more laid back in Philly, all the city really wants is fees, and parking ticket money. Last week with a parking placard, ($165 a year) let's you park free all day in most legal spots. I got $210 in parking tickets, or should I say my customers did.
    Jun 2007
    The Twilight Zone
    I am originally from South Philly so I know what you mean. Visiting my folks on Xmas will be fun - trying to find a spot and not getting stuck behind a double parker.
    Jun 2002
    Dacula, GA
    Don't get your tanks confused though. Acetylene "B" and a nitrogen tank look similar to the untrained eye. The nitrogene tank will have a large label where the nitrogen "B" tank won't have any. If you really want to know the difference go to Pye Barker, Air Gas or another gas company and ask to see a small nitrogen tank and a acetylene "B" tank. The HVAC boys may be using an acetylene "B" tank for brazing the line set. I have both a black and orange nitrogen tank both with labels on them. Good luck.
    Mar 2006
    Delaware
    Fortunately, the connection to the bottle is different!! <G>
