+ Reply to Thread
Results 1 to 7 of 7
Thread: Calculating BTU
    May 2012
    Calculating BTU
    Hello,
    Has any one tried calculating BTU through DDC Logic? There is Temperatures sensor in the supply and return and a flow meter in the Chilled Water line. Any inputs on the best way to do it through programming in DDC logic and experience will be helpful.
    Melbourne
    Quote Originally Posted by hmlhwl View Post
    Hello,
    Flow x Cp x td...more or less
    1 + 1 = 3 ( *** for very large values of 1)
    Be brave. You cannot get eaten by an imaginary tiger.
    Dec 2006
    What? Who? Where?
    Accurate sensors (matched temperature).
    kontrol out
    "Good" - Jocko
    "Open is as open does." - Forrest Gump
    "Can't we all just get a Lon?" - Garry Jack
    "BACnet: integration or interrogation?" - The Janitor
    "Interoperability? You can't handle interoperability!" - Nathan R. Jessup
    “What’s that? Aaa… open protocols? Don’t talk about…. open protocols? Are you kidding me? Open protocols? I just hope we can hardwire an interface!” - Jim Mora Watch it here!
    Oct 2008
    Kalispell, MT
    Hello,
    There's a lot to doing that. Different control systems have different issues doing things like this. JCI for instance might not calculate the value in a known time frame. Depending on what is going on in the system and whether you are using a controller or LCT. Siemens can do it in a somewhat known time frame or you can force it to calculate at least every second. If you are not time sensitive I would use the El Goog and figure out what it would take for your system.
    San Diego, CA
    Pacific Coast
    $.02 :
    Calculations offered are for water. Glycol has different specific gravity, which affects the BTU calculation.
    I also tie a status point (flow / no flow) to stop the calculation to avoid value windup when not flowing.
    John
    Dec 2001
    Wanna keep it simple try this product.
    http://www.onicon.com/?gclid=CKOg2snRkr4CFdDm7AodmSAAZA
    Rock solid reputation!
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
