Results 1 to 2 of 2
    Chicago, IL
    Not so easy EZ Trap
    Found this on a check up on a water source heat pump in a condo.
    Showed the pic to the homeowner and told them what was wrong with it. They said it was installed by another contractor after the ceiling collapsed due to a plugged drain.
    Ended up having to install a new EZ Trap kit because the float had been glued into the side of this one
    Jan 2014
    Mesa, Arizona
    Glued..... Hahaha. I can just imagine that same tech who installed it coming back wondering why the system isn't cooling because the float is stopping voltage. Smh
    We all make choices, but in the end our choices make us.
Comfortech365 Virtual Event
