    Humidifier and stat in Ductboard
    I just installed a HE225A with manual stat in a customers ductboard and it seems to not read very well, I dont think it is far enouph in the air stream, Is there a recessed plate or bracket that is offered to help this issue or should I just make it work in a differant location?
    Philadelphia
    is the humidistat in the return?
    burlington county n.j.
    Thumbs down
    you installed a humidifier on a ductboard system??????????
    i would think the humidistat not sensing would be the least of your worries.
    humidifier in ductboard ???????
    Yes and ah yes
    What is there to worry about ??? I have seen some pretty bad installs in ductboard due to tech not thinking long term and they will work loose over time , but not if it is done with correct mounting, Tell me your story's
