Results 1 to 2 of 2
    24VAC Terminals on Trane XV90
    I purchased an Aprilaire 700 humidifier and it's installed with the exception of the 24VAC to power the Aprilaire controller. Instructions indicate to power it off the R & C terminals of the furnace, but our Trane XV90 (White Rodgers controller 50A61-605) doesn't have a C terminal. I see the R terminal does have 24VAC when compared to the controller ground, but there's no obvious good place to connect into the controller ground.
    Question is... should I just power the Aprilare controller from a separate 24VAC transformer? Or is there a ground terminal on the furnace controller that I'm not seeing? Or could / should I tap in right after the fuse coming off from the transformer in the furnace?
    Thanks in advance!!!
    Sorry, site rules prohibit DIY discussions here. Contact whomever sold you the Aprilaire is best I can do for you.
